It is currently Wed Aug 05, 2026 3:29 am
Vehicle: yellow 83 sierra
Post Posted: Sun Nov 20, 2011 8:54 am
hi i was thinking that it might be nice to lift the body on my 4 door vit for larger wheels ect, i know that i need to have the chassis off to do it but im also doing other work to it which i need the body off and i found out that a few of my body mounts are stuffed and some have even bent the chassis so im thinking that its a good idea to do the body lift on it but i dont know how to do it
Post Posted: Sun Nov 20, 2011 8:55 am
are the lifting blocked bolted onto the body bolts then new bolts go through the chassis into the blocks?
Post Posted: Sun Nov 20, 2011 9:00 am
http://auszookers.com/index.php?name=Fo ... ic&t=15518
Buy them, easy to fit & very well made... :helloo:
Post Posted: Sun Nov 20, 2011 9:03 am
ok cool thanks i might go to a 4x4 joint closer to home and see what i can get
Post Posted: Sun Nov 20, 2011 9:20 am
you'll be wasting your time, they might have blocks but probably won't have the female bolts required.
Post Posted: Sun Nov 20, 2011 11:48 pm
well i just called up piranha to see what thier prices are and they said $400ish just for parts without the transfer stuff just for body only so i might look into this ^^^^ ones
Post Posted: Sun Nov 20, 2011 11:56 pm
is there a difference between the swb and the lwb body lifts are they the same?
Post Posted: Mon Nov 21, 2011 12:11 am
LWB has more body mounts, due to extra length..Dont think much else is different
Post Posted: Mon Nov 21, 2011 7:27 am
ok just that i got told today that there exactly the same as the swb haha
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 950 guests
