It is currently Mon Sep 21, 2026 12:01 pm
Post new topic Reply to topic  [ 36 posts ]  Go to page 1, 2  Next
Vehicle: Sierra Ute '87 Sj70
Post Posted: Tue Nov 22, 2011 12:39 am
has anyone seen or can make a 1 litre look a like grill that will clip into a newer leafy grill?
It's all coming together Armsup
Post Posted: Tue Nov 22, 2011 12:41 am
Yeah I saw some pics of a chrome one from the motherland. No idea on manufacturer though :(
Post Posted: Tue Nov 22, 2011 12:59 am
Alot of people change the whole front clip.
BUT, I have seen them. Trying to find them again now..
Still cant find them
But found pics
http://www.bing.com/images/search?q=sj4 ... &form=QBIR
google:
sj410
ja11
jimny
grill
Vehicle: 00 Jimny, 63 Haffy
Post Posted: Tue Nov 22, 2011 4:14 am
you can buy them somewhere.. one of the US suppliers.
found this
http://www.hawksuzukiparts.com/main_par ... amurai.htm
but Im sure I found who actually made them a while ago.
Post Posted: Tue Nov 22, 2011 4:34 am
I knew I saw them on lowrange. I did
http://www.lowrangeoffroad.com/index.ph ... ement.html
I cant find who make them but meh, lowrange.
Post Posted: Tue Nov 22, 2011 4:35 am
I think the lowrange image is a badly photoshoped version of the same image above... lol
Post Posted: Tue Nov 22, 2011 5:12 am
the reason i dont swap the whole clip is i just sent it too the panelbeaters to remove all the rust
but im looking for like a custom jobbie that i dont have to use the 1 litre light sorrounds just has the cuttouts of the 1l ill post photochopped pic of what i mean
Post Posted: Tue Nov 22, 2011 5:21 am
That is not what he is talking about, that is just a standard 1 litre grille, it wont bolt into a coily front clip.
Post Posted: Tue Nov 22, 2011 5:35 am
this is my stock grill but ill edit on my computer my phone editor sucks
Vehicle: 79 Lj80 stockman 94 swb Sierra
Post Posted: Tue Nov 22, 2011 5:45 am
You'll find you need maruti headlight surrounds rather then 1ltr to go with the grill if your looking to use your 1.3 gaurds
We are amphibious
Post Posted: Tue Nov 22, 2011 9:22 am
ok quite a bad pic but you get the idea
Post Posted: Tue Nov 22, 2011 9:24 am
i can find out the name of a company that does powdercoat that looks like chrome too =) (well, maybe... if my client that uses it will tell me who it is)...
Post Posted: Tue Nov 22, 2011 9:30 am
i was just thinking if the maruti has a plastic grill or even a lj and cut it up and plastic weld it in
Post Posted: Tue Nov 22, 2011 9:40 am
maruti is all metal
Post Posted: Tue Nov 22, 2011 10:35 am
I have seen a photo of a 1L grill with the 1.3nt grill behide it using it for the headlight surrounds
Post Posted: Tue Nov 22, 2011 11:05 am
seen what you are after a while ago on ebay was a stainless or ally 1ltr grill that just screws on over the top of your existing grill was under suzuki samurai it looked ok but you could tell it was just a cover screwed on over the top
Post Posted: Tue Nov 22, 2011 12:07 pm
Stainless are an afterthought. Anyone can do that..
This is what he is talking about, All you guys are giving me a fucking headache. If you bothered to search on what i said to search for, you would of found it by now.
Here you fooking noob ends:
http://origin-labo.jp/pc/jimny/grill.html
YES look at this link^^
OH wow, Look at this one:
http://www.auszookers.com/index.php?nam ... c&start=30
Here's another option, Not 1L but nice:
http://www.bing.com/images/search?q=ja1 ... &FORM=BIFD
ANOTHER 1L PLASTIC OPTION:
http://www.bing.com/images/search?q=+su ... ORM=IDFRIR
Cant find supplier though.
Wholly crap, Another option:
http://www.roadlessgear.com/html/techar ... index.html
Post Posted: Tue Nov 22, 2011 8:07 pm
A little off topic but going by the above you can not bolt a Maruti 1 L grill to a set of NT 1.3 guards?? I thought you could??
Post Posted: Tue Nov 22, 2011 9:56 pm
Yes you can
The front grill section clip is braised in though. So its not a simple bolt in swap, Unlike a whole front end.
Post Posted: Tue Nov 22, 2011 11:32 pm
[quote
http://www.roadlessgear.com/html/techar ... index.html[/quote]
this is the one I saw
Post Posted: Wed Nov 23, 2011 2:01 am
Yes you can
No the front section is not braised in, it is bolted in with some factory white seam sealer and can be removed. The only problem with fitting a 1 litre grille panel to WT guards is that guards comprise of an inner, an outer and the headlight panel, the 1 litre guards have 4 small rectangular cut outs on the headlight panel where the 1 litre headlight surround clips in, the WT does not. So you have 2 options, use 1 litre guards and convert them to WT or carefully cut the 4 rectangular holes in each headlight panel
All this however is off topic because the original post is about the factory/aftermarket coily front which is released somewhere in the world with something very similar to a 1 litre grille.
By the way here is an aftermarket grille that is a direct swap for a 1300 NT or WT grille to give it that 1 litre look.
Post Posted: Wed Nov 23, 2011 2:09 am
This is what he means.
Post Posted: Wed Nov 23, 2011 4:18 am
the roadless gear one looks the goods for $20
Post Posted: Wed Nov 23, 2011 4:21 am
nah mate i own a leafy but the black one you posted is the go you got a link?
Post Posted: Wed Nov 23, 2011 5:57 am
My grill metal section is bolted and braised in! Off a stock 88.5 wt hardtop..
Post Posted: Wed Nov 23, 2011 6:02 am
Your front may have been repaired at some time then cause I have pulled heaps apart, in fact I did one this arvo, no brazing on it
Post Posted: Wed Nov 23, 2011 7:09 am
hmm.weird.
Post Posted: Wed Nov 23, 2011 7:31 am
The white one has jeep on the bonnet.. 8O good way to wreck a suzuki bonnet!
back in a built sierra!
Post Posted: Wed Nov 23, 2011 7:55 am
i was thinking the same thing as well as the softop rubber mount to hold the windscreen down
Post Posted: Wed Nov 23, 2011 7:56 am
Armsup Grimbo :helloo:
Users browsing this forum: No registered users and 97 guests
