It is currently Thu Jul 23, 2026 5:37 am
Post Posted: Sun Jan 11, 2009 3:15 pm
G'day
I've noticed a strange thing happaning to rev while driving. tacho jumps up and down about 200-400 RPM usually jst after shifting to higher gear. I have no idea what can it be. fuel problem (pump or carby?), coil. it is not noticable for passanger, car doesn jerk, I can't really feel it through accelerator pedal, however I feel the RPM jump throgh gear stick. Anyone have any ideas, what that can be?
Thanks
Chris
Post Posted: Sun Jan 11, 2009 3:19 pm
Sliping clutch?
Post Posted: Sun Jan 11, 2009 4:38 pm
no clutch is ok, I changed it for the heavy duty one last year.
Post Posted: Sun Jan 11, 2009 11:08 pm
I have heard a few people comment their tacho did this just before the ignition module died
Post Posted: Sun Jan 11, 2009 11:42 pm
This is a common occurence on quite a few makes and models of cars just before the module craps itself. The early magna's and Camira's were renown for it. It might go for a while longer yet, but it's better not to take the chance.
Post Posted: Mon Jan 12, 2009 1:17 am
i also had a customers car do this....turns out the 8mm bolt to lock the dizzy was loose.
Post Posted: Mon Jan 12, 2009 2:14 am
thanks, what is that ignition module? Is it dizzy or something else? Is it expensive?
Post Posted: Mon Jan 12, 2009 2:47 am
I forgot to mention that I have vitara 1.6 carby engine in my sierra, I guess that this dosn't matter in this case.
Post Posted: Mon Jan 12, 2009 11:08 am
I'm not 100% sure because I've never even had my distributor cap off yet, but I think the module on a Sierra or Vitara is located inside the distributor. On some other types cars they are bolted on the side of the dizzy, and some other models again are fitted away from the dizzy somewhere else in the engine bay eg 5 litre Holden VN-VS. They're not hard to replace, and even though it has probably just clapped out over time, when you replace the module, check out the rest of the ignition components are ok. Things such as high ignition lead resistance, can put an extra load on the module and cause it to fail prematurly.
Post Posted: Fri Jan 16, 2009 1:45 am
thx for help. I checked all cabels around dizzy and coil and found one coming from dizzy to coil nearly broken. I soldered it and everything is ok.
cheers
Users browsing this forum: Google [Bot], Google Adsense [Bot], rpmwrx and 134 guests
