It is currently Sat Jul 18, 2026 7:37 pm
Post Posted: Thu Dec 01, 2011 7:47 pm
after the throttle body off a suzuki vitara, the one off the motor i bought isnt in the best condition however when i bought the engine he did say the throttle position sensor was buggered which is another problem with it.
but i suspect that he has taken it off his own motor and swapped it with the motor i bought, anyway if someone has this part or the whole intake and can send it or live near Millicent SA that would be great.
Post Posted: Thu Dec 01, 2011 7:48 pm
oh its a g16b, 1.6L vitara motor
Post Posted: Thu Dec 01, 2011 8:26 pm
Mitsubishi or Denso electrics?
How many wires to the AFM?
Post Posted: Thu Dec 01, 2011 10:45 pm
Ah its Mitsubishi electronics, three wire air flow meter but that's not the trouble. It's the throttle position sensor.
Post Posted: Fri Dec 02, 2011 9:01 am
Yes I understand the problem.
In order to be able to supply the right sensor, I need to know which of the several different ones it is.
Just to be sure, can you supply the part number?
Post Posted: Fri Dec 02, 2011 9:22 am
Mm no I'm pretty shore of the number because its rubbed off, I think its a 4 wire jobby. :)
Post Posted: Sat Dec 03, 2011 3:19 am
can you help me out :)
Post Posted: Mon Dec 05, 2011 1:52 am
I have a Vit 4 wire TPS here.
It is part #13420-61B00.....198500-0450
Post Posted: Mon Dec 05, 2011 2:41 am
How much you after?
Post Posted: Mon Dec 05, 2011 5:11 am
$60 delivered.
Post Posted: Mon Dec 05, 2011 6:18 am
sounds good to me
