It is currently Sun Nov 08, 2026 7:23 am
Vehicle: 2001 M18a Jimny
Post Posted: Fri Dec 09, 2011 8:51 am
Is there a way to disconnect to the beeper/warning tone that goes off whenever you have left the lights on or when the keys are in the ignition and the door is open?
It makes listening to the radio with the door and car turned off impossible, and is a painful sound anyway..
thanks in advance guys!
http://www.facebook.com/omalleyimagesonline
Post Posted: Fri Dec 09, 2011 9:03 am
Turn the music up louder :helloo:
Post Posted: Fri Dec 09, 2011 9:15 am
Find said beeper & drill a small hole through the center of the speaker, if you cut wire's other thing's will play up..
Or, you can pull the wire off the driver's door light switch, but, other thing's will play up... :lol:
Post Posted: Fri Dec 09, 2011 9:21 am
wind the windows down & close the doors when listening to music?
i like my buzzer, saved me from leaving the lights on a few times :oops:
Vehicle: LJ20 LJ50
Post Posted: Fri Dec 09, 2011 10:25 am
Camels have nice toes
Vehicle: LJ20 LJ50
Post Posted: Fri Dec 09, 2011 10:26 am
or get shep to weld something on the car
Post Posted: Fri Dec 09, 2011 10:46 am
Hahahahahahahahahaha ............. .................... .... ....... Burn
Post Posted: Fri Dec 09, 2011 6:12 pm
mine doesn't beep quick enough ive left the lights on once or twice after driving subarus for 6 or so years (they turn them off for you) you forget to turn them off.
Post Posted: Fri Dec 09, 2011 6:52 pm
Find said box & unplug, I seam to remember doing that one day when it was shitting me, had my head under the dash for a while with ing on.
Just make sure all light's & shit still work tho..
Post Posted: Sat Dec 10, 2011 10:58 am
Thanks Stekky, I shall go for a hunt tomorrow morning. Hopefully I'll find the source of it before it drives me up the wall.... :lol:
Post Posted: Sat Dec 10, 2011 11:01 am
Im not a fan of buzzers. It can run flat :lol:
Vehicle: Clown Car..
Post Posted: Sat Dec 10, 2011 12:36 pm
http://www.suzuki-forums.com/suzuki-jim ... moval.html
maybe!?
Post Posted: Sat Dec 10, 2011 12:38 pm
can you not find it, then fit a switch to it? so when it annoys you, you can turn it off... otherwise you can leave it on to do its job =)
Vehicle: 02 Suzuki Jimny
Post Posted: Sat Dec 10, 2011 1:10 pm
My interior light doesn't turn on when I open the drivers door and I don't have a beep when the lights are left on... I wonder if my switch is disconnected.... mmmmmm
TF
Post Posted: Sat Dec 10, 2011 1:11 pm
my interior light in the sierra only works when i clean the contacts in the switch.... it works for about a month then gets corroded again and stuffs up.
Post Posted: Sat Dec 10, 2011 10:48 pm
TF
Not all jim's have the lil annoying box......
Vehicle: LJ20 LJ50
Post Posted: Sat Dec 10, 2011 10:53 pm
steak_knife wrote:
TF
zookylizs does :helloo:
Post Posted: Wed Dec 21, 2011 11:34 am
I pulled my instrument cluster out and removed the little buzzer from the holder. Didn't take me that long either. Just a few screws and a small flat blade.
Users browsing this forum: Google Adsense [Bot] and 136 guests
