It is currently Thu Jul 23, 2026 5:11 am
Post Posted: Fri Jan 16, 2009 11:09 pm
just wondering whats the best way to remove the "splash of paint" stickers of the side if a white vitara? i just bought one and the stickers fades from blue to purple, not a real macho colour.
do u just peel?
heat it up?
soak it?
use chemicals?
Vehicle: 75 Cruiser
Post Posted: Fri Jan 16, 2009 11:13 pm
heat gun is good... heat the crap of it but don't burn the paint.
solvent can clean up the left over glue.
lesspostingmorewheeling
Post Posted: Fri Jan 16, 2009 11:22 pm
is there anything that won't melt the paint underneath that will work?
Post Posted: Fri Jan 16, 2009 11:27 pm
use a heat gun, slowly peel the edge then heat the section in front thats still attached to the panel. be carefull not to heat too much as it will make the sticker brittle.
no easy answer that i know of, slow and carefull
85 NT, SPOA, 2" BL, sliders, f&r lockers, bull bar
Post Posted: Fri Jan 16, 2009 11:35 pm
Take the doors off will get rid of most of the graphics.
Just kidding.. :lol:
Heat gun, good scraper blade and and a product called 'Oomph' to clean up glue residue.
Jas.
Post Posted: Fri Jan 16, 2009 11:36 pm
There is a wheel that you can get for your Grinder i've seen it at most tool shops. Again you can't leave it in one spot too long.
http://www.signwarehouse.com/TT-VR-p-HT-STPELM.html
Post Posted: Fri Jan 16, 2009 11:44 pm
will a hair dryer do as i dont have a heat gun..?
Vehicle: 75 Cruiser
Post Posted: Fri Jan 16, 2009 11:50 pm
get the hairdryer up real close and get some heat in there, and report back to us :)
Vehicle: MY2019 Jimny
Post Posted: Sat Jan 17, 2009 12:08 am
Just peel off as much as you can by hand, then apply ti-tree oil or eucalyptus oil (can't remember which) to remove the stick residue.
It worked on my old lux...
Post Posted: Sat Jan 17, 2009 12:17 am
i used a sharp razor blade really carefully then eucalyptus oil.
worked great.
Post Posted: Sat Jan 17, 2009 12:38 am
Yes a hairdryer will work just take longer ,then use wax and grease remover.
Post Posted: Sat Jan 17, 2009 1:37 am
do u just peel?
heat it up?
soak it?
use chemicals?
wait for another stinking hot day & park it in the sun, then start at one end & slowly peel it off. it's all in the angle of attack when peeling the wak decals off
Post Posted: Sat Jan 17, 2009 2:38 am
That is a caramel wheel and they work great on acrylic stickers like pinstripe but not on plastic stickers like Suzuki graphics.
Post Posted: Sat Jan 17, 2009 2:50 am
OK then, I have nothing!! Heat gun is the only other way I know too. Good luck!!
Post Posted: Sat Jan 17, 2009 3:10 am
u know what, i went out with my trusty thumb nail & managed 2 get a sticker off. but then ur thumb hurts, so 1 sticker @ a time. might have 2 go over it with big kevs goo remover after..
Post Posted: Sat Jan 17, 2009 7:32 am
Bristol paint suppliers sell an excellent product aimed at removing stickers, the sticky residue, and graffitti.
It's under $10
I've never used it.. I found out about it just after I finished taking mine off with razors. (Always the way)
aka
aka
Post Posted: Sat Jan 17, 2009 8:21 am
Got a 40 cal Glock that will remove just about anything. I hear a 12 gauge will do the same.
Experience is something you dont get until just af
aka
aka
Post Posted: Sat Jan 17, 2009 8:30 am
http://www.youtube.com/watch?v=kBjUDCyDCuI
Vehicle: 75 Cruiser
Post Posted: Sat Jan 17, 2009 2:33 pm
try leaving it in the sun for a while before taking the sticker off with your nails. I did this once, worked pretty good. Depends how old the stickers are i think.
Post Posted: Sat Jan 17, 2009 2:47 pm
mine came off real easy, unfortunately they werent factory ones but put on by a dealer to hide some dents and the glue affected the paint, so now I have a big grey crazy crack swish up the side :)
Post Posted: Sat Jan 17, 2009 8:01 pm
Don't use metal razor blades!! Too much risk of damaging paint. You can get plastic blades that help. Also a citris based solvent works well on the residue. Heat gun or hair dryer as already mentioned.
Post Posted: Sat Jan 17, 2009 8:21 pm
hair dryer works well but it takes a long time especially on mine because the graphics are 26 individual 4mm strips that run the whole length of the car 8O
Post Posted: Thu Jan 29, 2009 2:25 pm
I got mine off in two hours with Two people.
1) Park Vehicle outside so that the panels are hot.
2) Create a mix of 1/8 thinners. 2/8 Citrus Orange sticker remover and 5/8 Prepsol (aka Wax and Grease Remover)
3) Use a hair dryer (Thats what i used when the heat gun shat itself)
and carefully heat up the associated area while using a plastic ruler (be careful using a ruler because it slightly scratches the paint to some extent) or proper plastic scraper to remove the sticker.
NOTE: If you heat up the sticker evenly it should come off as one whole piece. If the sticker cracks off or breaks its because the sticker mostlikely wasnt hot enough.
4) Use the Wax and Grease remover / Thinners / Citrus Mix to remove the sticky Residue.
Also take note that my sticker was in real bad shape. As in it was about 20 years old and was cracked and sperarted in some areas. I honestly thought it was not going to come off without wrecking or scratching the paint bad enough to need a respray.
Post Posted: Thu Jan 29, 2009 9:07 pm
bring your zook over here, its been above 40 degrees for the last 3 days and not looking to cool down anytime soon! stickers should just slide off, LOL
Post Posted: Thu Jan 29, 2009 9:09 pm
ha! just realized you are in Adelaide... you should have no trouble
Users browsing this forum: Google [Bot] and 157 guests
