It is currently Sun Nov 08, 2026 7:16 am
Post new topic Reply to topic  [ 44 posts ]  Go to page Previous  1, 2
Post Posted: Fri Dec 09, 2011 9:10 pm
i still fail to se the issue when the shackle doesnt invert under full compression.
so after reading through your link, it doesnt answer whats actually wrong with having a greater shackle angle than most, especially when it works with no ill effects at all.
i could understand if it was smashing the shackle against the chassis as in some of the pics, but i beleive that only happens when u have to much arc in the spring.
Post Posted: Fri Dec 09, 2011 9:12 pm
even under full compression u can see the shackle is still within its limits
Post Posted: Fri Dec 09, 2011 9:23 pm
As you can see the shackle angle is very low which has several negative effects: 1. Springs bottom out easily over bumps. 2. Soft ride handling on corners. 3. Somewhat limited spring flex.
Taken from the link in the thread I posted :roll:
Post Posted: Fri Dec 09, 2011 9:30 pm
1. not in my springs 2. it corners better than most sierra's
3. the spring flex's fine
some first hand info would be nice for once not fucking cut and paste from pimply faced teenagers :roll: :roll: :roll: :roll: :roll: :roll:
Post Posted: Fri Dec 09, 2011 11:02 pm
:lol:
What springs are you using Mick ? I am pretty sure Simon is still RUF with stock chassis mount and just extended shackle on the front. I had a FULL RUF done on mine but I used a custom length main in a soft 3 inch pack and it flexed and felt pretty good.
Post Posted: Fri Dec 09, 2011 11:05 pm
If you turned that shackle around, you would, in a way, have anti inversion....
mine was a 3 pack of efs 2" lifted
the 3/4 worked alot better when i did it too
Oh, & nice car................ 8)
Post Posted: Fri Dec 09, 2011 11:09 pm
I run a std rear main & 3 leave's out of a 2" pack, front sits lower...
I cut & shut rear hanger's & extended rail's but frucked the math for 2" main's, going to redo one day.
Post Posted: Sat Dec 10, 2011 8:16 am
wow didnt know this popped up again :lol: mods can close this if they want car is going for RUF tommorow
Sierra, 32's, Airlocked, 6.5'd, hopefully ruf soon
please close
Post Posted: Sat Dec 10, 2011 8:30 am
Aaron wrote:
please close
Don't worry, there's still some useful info here. Like most of AZ, you just have to wade thru the useless crap to find it :lol:
Post Posted: Sun Dec 11, 2011 1:34 am
Scrawn wrote:
Aaron wrote:
please close
good tech? :lol:
Post Posted: Sun Dec 11, 2011 1:58 am
Aaron wrote:
Scrawn wrote:
Aaron wrote:
please close
good tech? :lol:
Not good tech, useful info :wink:
Users browsing this forum: No registered users and 126 guests
