It is currently Sun Nov 08, 2026 11:39 am
Vehicle: 85 WT with SR20DE N/A
Post Posted: Fri Dec 16, 2011 12:29 am
Hey guys,
just found out today that my zook has run out of rego i after any info on how to get back over pit and regoed maybe even a check list of the things the look for
also if people had a list of what i am aloud to do as i think i am going to have to build the zook from ground up
i feel really stupid for letting it run out
thanx for any help you can give much appreciated
ROBBIE REILLY :please: :oops!:
Vehicle: Vitara 90'
Post Posted: Fri Dec 16, 2011 12:37 am
How long has it been out of rego? Isn't there a period of 3 months or something that you have till it has to go over the pits again?
From my experience, just go over everything if it's broken fix it, if it's dirty clean it. If you present them with a clean car that doesn't look like it's just spent the last 20 years of it's life in a wrecking yard then they are more likely to give it the ok.
Post Posted: Fri Dec 16, 2011 12:42 am
aparently the 3 months was 13 nov i neva got anything in the mail at all :(
so just rebiuld the car ground up then really
what about mods??
Vehicle: Vitara 90'
Post Posted: Fri Dec 16, 2011 12:44 am
what about mods??
If your car is that bad that you need to rebuild it from the ground up, it's probably a good thing it's out of rego.
Do you have any mods on it at the moment?
Edit: Just had a quick look at your build thread, are those seats approved? are your tyres sticking out from the guards? might need to fix that first.
Post Posted: Fri Dec 16, 2011 12:47 am
what about mods??
at moment 2 inch lift that is saggy and 30 inch tyres that is about all but the body is rough and wire looks untidy
Post Posted: Fri Dec 16, 2011 12:49 am
and has racing seats
Vehicle: Vitara 90'
Post Posted: Fri Dec 16, 2011 12:52 am
Yeah you probably won't get passed on those seats depending how well the guys does his job + the 30's might be pushing it too. I'd see if I could swap them out for stock ones.
[quote=Zookfan]maybe go over everything to make sure nothing little or major has been missed? like blown bulbs, fresh oil leak?? gauges not working? ect
that way you know you won't have any nasty surprises![/quote]
Did you do this? is everything that should work, working?
Post Posted: Fri Dec 16, 2011 12:54 am
yeah i think i will rebiuld the hole thing make it a safer zook thanx Microwire looks like i be busy this holidays and have no money
Vehicle: Vitara 90'
Post Posted: Fri Dec 16, 2011 12:56 am
lol, enjoy pulling it apart and just cleaning bits, you will learn a lot about how the car works and what will break and when. Plus it's FREE!!
Post Posted: Fri Dec 16, 2011 1:00 am
yeah i supose i have to look at the positaves thanx for making me relise that
Vehicle: Vitara 90'
Post Posted: Fri Dec 16, 2011 1:02 am
Edit:
No Problems Mate enjoy your car ;)
Post Posted: Fri Dec 16, 2011 1:16 am
Microwire wrote:
np ;)
ban!
Vehicle: Vitara 90'
Post Posted: Fri Dec 16, 2011 1:21 am
Microwire wrote:
np ;)
ban!
Don't know what you're talking about.
Microwire wrote:
np ;)
ban!
ban what???
Post Posted: Sat Dec 17, 2011 12:37 am
go merinos mechanics off dixon road next to parsons trim shop in rocko i have taken heaps of cars to them they are pretty good good just dont take a shit box to them cause they will write you up a big list!!
Post Posted: Sat Dec 17, 2011 1:40 am
have a look on the website! its www.transport.wa.gov.au there is heeps of info on there about what exactly is inspected when they do a car inspection. i also found some checklists a few months ago when i was looking at getting a shitter (vitara) i had licensed (turned out it had a bent chasis so i just sold it)
first of all
http://www.transport.wa.gov.au/licensing/20382.asp
you use that thingo to tell ya when ya vehicle license expires
here is a PDF of a basic checklist of what to do before you take it over the pits!
http://www.transport.wa.gov.au/mediaFil ... ehicle.pdf
go through and make sure all the basics are done! and try and tidy it up as best you can! make sure its clean and tidy! then take it to the pits with your fingers crossed! chances are it will fail the inspection and they will give you a "pits list" detailing all the defects that they have noted, the advantage of this is that you take it home and repair everthing on the list and when you take it back all that they will inspect is the items on the list! the better that the car is presented, the less picky they are likely to be with the inspection!
also i have a full set of standard SWB springs (saggy as) and 205s on rims ya can borrow if ya want, while you put it over! and if the racing seats meet design standards and apear to be mounted securely and without welds you may get away with it.
but if not! suzishop sell retrimed sierra seats for about 400 bucks a pair, and they look and feel great to sit in, they might even buy ya racing seats of ya!
if ya get a chance! have a chat to the bloke before he does the inspection, tell him the industrie you work in ;) that will get ya browny points ;)
THINKING BEFORE POSTING!!!
Post Posted: Sat Dec 17, 2011 1:50 am
high pressure underneath and tidy it up as much as humanly possible
then get your mum or dad to take it to midland pits(they go easy on olds).
because suzistore is right next door they get heaps of zooks over so generally they are a little more forgiving, just shut your mouth and let the guy do his job he wont want to talk to u till after the inspection.
then get everything on the list done asap and make sure u pay for your inspection prior to your inspection time
Post Posted: Sat Dec 17, 2011 3:31 am
first of all
thanx for the lists mate help alot hahaha and sometimes what i do for living helps and some times it dont it just depends on there view on the hole iderstry
Post Posted: Sat Dec 17, 2011 3:32 am
yeah that not a bad idea at all take there and get me parents to do it
thanx
Post Posted: Tue Feb 21, 2012 5:00 pm
So...what happened....did it pass?!
Vehicle: '91 Sierra, Fluffy Dice.
Post Posted: Wed Feb 22, 2012 6:44 pm
Fucken hard hahahah
If at first you don't succeed, get a bigger hammer
Post Posted: Wed Feb 22, 2012 8:39 pm
ridzilla wrote:
Fucken hard hahahah
Really? My mate just took his patrol over the pit's with a 5" superior engineering lift and it passed. :?
Post Posted: Wed Feb 22, 2012 11:33 pm
depends on the pits - warwick were a bunch of asshats when i put mine over.
Post Posted: Wed Feb 22, 2012 11:35 pm
best place to go now days :)
Users browsing this forum: No registered users and 55 guests
