It is currently Sun Nov 08, 2026 9:46 am
Post Posted: Mon Dec 26, 2011 2:19 am
there some strange bits on this combo, dunno what to do with this crazy g/box shifter and check out well.. i spose you could call it a dump pipe
haha crazy japs - small pics only :cry:
Post Posted: Mon Dec 26, 2011 3:08 am
i've got better than 20/20 vision & i'm fucked it i can see what i'm looking for. :thefinger:
you're pics are always tiny & shit, fix it. :P
Vehicle: Sj70 tintop
Post Posted: Mon Dec 26, 2011 3:54 am
is anything like a g6?
hope its fly.
Sj70 tintop
Post Posted: Mon Dec 26, 2011 4:40 am
similar to the jimny shift linkage??
maybe also similar to the lj linkage
Post Posted: Mon Dec 26, 2011 7:32 am
in the last pic where the tailshaft ends is the end of the g/box another 40cm after that is the shifter 8O on some weird mechanism
Post Posted: Mon Dec 26, 2011 7:35 am
yep. LJ run a similar setup. but the mechanisim is built into the body.
Jimnys i believe have a remote shift linkage
Post Posted: Mon Dec 26, 2011 11:33 am
MrRocky wrote:
there some strange bits on this combo, dunno what to do .. check out well.. i spose you could call it a dump pipe
The "Dump Pipe" is the Cat Converter. Turns Cats into harmless gases.
Post Posted: Mon Dec 26, 2011 10:41 pm
cap engine and gear box i presume?
we had a couple of goes trying to run the cap box in my old sierra with verying levels of success.
you can unbolt the 'extension' part of the box, and this will reveal the shift rails just like in a sierra box. you then need to build a new cover for the top of the box and come up with a shifter.
if that's unclear, i can probably take some photos of my old one in the shed.
the simplest and best solution is to find a gearbox out of an F6A engined jimny, but these are not going to be very common. that will get you a slower first gear for better crawling, and it will put the shifter in the right spot.
re the dump pipe - build your own. we ran a 2.25" exhaust with a cat out of a commodoore.
Post Posted: Mon Dec 26, 2011 10:48 pm
mmm
Users browsing this forum: No registered users and 437 guests
