It is currently Thu Aug 06, 2026 7:12 am
Post Posted: Thu Dec 29, 2011 3:19 am
has anyone done the hole high pinion thing on sierra's to lift up the pinion higher (mines a wt)
Post Posted: Thu Dec 29, 2011 4:10 am
Front or rear? What are you trying to achieve?
Post Posted: Thu Dec 29, 2011 4:19 am
Only coily's come with a high pinion front. If you want any other high pinions you will need custom reverse cut gears. Or flip your housings.
Post Posted: Thu Dec 29, 2011 4:59 am
So does the almighty Jimny :)
Post Posted: Thu Dec 29, 2011 6:49 am
Front or rear?
As far as I know, neither a coil or Jimny high pinion front diff will bolt in to a WT front.
There's little point using one in the rear - a high pinion diff used in the rear is about 20% weaker than a normal rear diff.
Post Posted: Thu Dec 29, 2011 8:12 am
Front or rear?
sj80 front will bolt in.I think if u change side gears in diff it will work.
Post Posted: Thu Dec 29, 2011 10:00 pm
i don't want to use a coily front diff, and other than that there is no real way to do this...???
Post Posted: Thu Dec 29, 2011 10:04 pm
then id say no.
Or that.. Why do you want to do it anyway?
Post Posted: Fri Dec 30, 2011 1:04 am
since the car is so low im trying to lift them up so the don't hit rocks etc
Vehicle: LJ20 LJ50
Post Posted: Fri Dec 30, 2011 7:56 am
What size tyres are you running????
Camels have nice toes
Post Posted: Fri Dec 30, 2011 8:45 am
Ive got a coily high pinion in the rear of my car, with an air locker.
seems to work ok
Post Posted: Fri Dec 30, 2011 11:06 am
31's then when they get low 33's
Post Posted: Fri Dec 30, 2011 11:28 am
seems to work ok
nothing. fits a coiler..... oh wait
Post Posted: Fri Dec 30, 2011 11:44 am
Where in the Rockhampton area have you been hung up on your pinion carrier? I'm on 235's and have never experienced that.
Post Posted: Fri Dec 30, 2011 12:01 pm
out at the water towers back when it had 235's, yes it has 31's now but i wouldn't mind doin it when i pull my diffs apart do it all at once
Users browsing this forum: No registered users and 418 guests
