It is currently Sun Nov 08, 2026 9:41 am
Vehicle: SJ70 1993
Post Posted: Thu Dec 29, 2011 10:34 am
I ran a search to see if there was a thread alread open but i couldnt find definite answers.
My questions are, if im to change out my 1990 1.3 to a 1.6 vitara or swift gti. Besides the loom ect are there other bits needed example will the gearbox bolt straight on or do you need an adapter?
i just ask as buying an engine is all good but i just gotta know if there will be other stuff i need to buy aswell so i can get it all in one go and put it together and have no problems (besides my own faults)
Cheers for any input you guys have
-Shiv
Lock, Drop and roll
Vehicle: SJ51T
Post Posted: Thu Dec 29, 2011 10:47 am
http://auszookers.com/index.php?name=Ne ... cle&sid=41
http://auszookers.com/index.php?name=Ne ... cle&sid=50
Vehicle: SJ70 1993
Post Posted: Thu Dec 29, 2011 10:56 am
sweet exactly what i need. what key words did you use to find those?
Lock, Drop and roll
Vehicle: SJ51T
Post Posted: Thu Dec 29, 2011 11:05 am
I went to 'tech articles' at the top of the page then clicked on 'all tech articles'.
Vehicle: SJ70 1993
Post Posted: Thu Dec 29, 2011 11:07 am
ah cheers ill remeber that for future searches
Lock, Drop and roll
Post Posted: Thu Dec 29, 2011 12:08 pm
1.6 if you like power, if you like to rev the c*#t out of it go the GTi eng
Vehicle: SJ70 1993
Post Posted: Thu Dec 29, 2011 12:25 pm
yeah i was leaning towards the 1.6.
Lock, Drop and roll
Online
Post Posted: Thu Dec 29, 2011 7:53 pm
If you go with the 1.6, consider using the manual or auto gearbox from the vitara as well. Although I'm more into autos, the vitara manual is superior to the sierra one, mostly because it allows the use of a bigger clutch. Doing this eliminates the need for a gearbox/engine adapter plate, but dies require some work to the gearbox mount, transmission tunnel and jackshaft.
Post Posted: Thu Dec 29, 2011 8:11 pm
Rumour has it that the Vit manual has a much heavier flywheel compared to the Sierra as well?
Post Posted: Thu Dec 29, 2011 8:50 pm
Only because of its extra diameter. :wink:
Post Posted: Thu Dec 29, 2011 9:40 pm
When you remove the transfer from the gearbox are you left with something similar to the end of a sierra box? I've only played with divorsed transfers/separate boxes, what needs to be done to the jackshaft?
Users browsing this forum: No registered users and 290 guests
