It is currently Sun Nov 08, 2026 9:47 am
Post Posted: Thu Dec 29, 2011 5:00 am
Hi all, I have been given some man Vitara front diff heads and want to put them in my Samurai. My current set up is 1.6 Vit motor, 1ltr transfer case , 2inch sus lift , 2inch body lift, Vit power steer, 31's . Now if I chuck in the crown wheel and pin's out of the vitara what's my top end going to do?, maybe 32's,33's could be on the cards? or should I go back to a Samurai transfer case?
cheers Al
NZ ( home of the Rugby World cup :lol: )
Post Posted: Thu Dec 29, 2011 5:05 am
cheers Al
NZ ( home of girly men :wink: )
here ya go
http://www.grimmjeeper.com/metric_gears.html
Post Posted: Thu Dec 29, 2011 5:42 pm
Hay shep.... :finger:
Post Posted: Thu Dec 29, 2011 6:17 pm
Did the calculations. Your current RPM at 100km/h is about 3500. Your new RPM with the 1.0l case and 5.12:1 diff gears will be about 4750, or in other words, revving its nuts off :lol: If you put a standard transfer in with 5.12:1 diff gears your RPM will be 4250, so not much better. I think you would be much better to just leave the diffs alone and either buy transfer gears or do a rocklobster because at the moment your high range gearing is about standard so you probably don't want to change it.
When I did the calcs I used the numbers from the factory owners manual and I got the 1.0l transfer ratios from one of 303zukes posts. :helloo:
Post Posted: Thu Dec 29, 2011 9:51 pm
You'd have AWESOME acceleration in high though!!
Post Posted: Fri Dec 30, 2011 12:23 am
Do it and then fit 36's
Post Posted: Fri Dec 30, 2011 12:47 am
And what size tyres did you use for those calculations, Al
Post Posted: Fri Dec 30, 2011 1:00 am
31"
Post Posted: Fri Dec 30, 2011 1:08 am
And with 33's with 5.12 diff gears and 1.0l tcase the revs at 100 will be 4500. With a standard tcase and 5.12 diff gears it will be about 4000.
Users browsing this forum: No registered users and 445 guests
