It is currently Tue Oct 20, 2026 1:17 pm
Post Posted: Fri Jan 30, 2009 2:10 am
Anyone happen to know the weight difference between a G13A, and a G16B MPFI.
I expect that its not much, but the engineer that will be certifying the swap in my Sierra has asked the question.
Post Posted: Fri Jan 30, 2009 2:15 am
easier to find another engineer
I reckon the ecu and wiring would weigh more than the difference in engines!!!!!
Vehicle: MY2019 Jimny
Post Posted: Fri Jan 30, 2009 2:24 am
Wouldn't the G16 weigh less, because of larger bore?
Post Posted: Fri Jan 30, 2009 2:34 am
probably heavier rocker cover and inlet though
Post Posted: Fri Jan 30, 2009 3:29 am
Possibly right!!
He's definitely not familiar with Suzuki engines so hopefully once he sees what the physical difference is it will be a non-issue.
Its not like I'm trying to drop a cast iron V8 in..
I expect the G16 will be a little bit heavier due to it being a 16V head vs the old 8V, but would have to be less than 5kg.
Anyway - just thought that someone may have had weight specs at their fingertips - appears not.
Post Posted: Fri Jan 30, 2009 5:20 am
Just bull shit too him, what's he going to do check. They're heavy to move by yourself so say 63kg for the 1.3 and 69kg for the 1.6 if he says that sounds light say it the bare engine. but I think that would be on the heavy side of what they are.
Vehicle: LJ20 LJ50
Post Posted: Fri Jan 30, 2009 10:21 am
I had a 1.3 twin cam swift engine. I was able to carry the complete engine from the ute to the back yard. I was shattered afetrwards but they are not that heavy really.
Just draw up a table like this one and add an extra catergory of weight. then say you got the infomation from the technical department at suzuki
Manufacturer Suzuki
Type Straight-3
Bore 2.91 in (74 mm)
Stroke 3.03 in (77 mm)
Displacement 61 in³ (1000 cm³)
Block alloy Aluminum
Head alloy Aluminum
Valvetrain SOHC or DOHC (Model Dependent)
Turbocharger Depending on Model
Fuel system Carburated or Fuel Injected (Model Dependent)
Cooling system Watercooled
Power output 48 hp (36 kW) @ 5100 RPM
Specific power 0.79 hp/in³ (36 kW/L)
Torque output 57 ft·lbf (77 N·m) @ 3200 rpm
Compression ratio
Camels have nice toes
Vehicle: 75 Cruiser
Post Posted: Fri Jan 30, 2009 11:27 am
A12 87 kg 192 lbs
A14 93 kg 205 lbs
L18 118 kg 260 lbs
CA18ET 118 kg 260 lbs
QR25DE 121 kg 267 lbs
CA18DET 128 kg 282 lbs
SR20DE 139 kg 306 lbs
SR20DET 149 kg 328 lbs
FJ20ET 166 kg 366 lbs (205 hp)
KA24DE 167 kg 368 lbs (est)
With Transmission:
SR20DET 490 lbs
RB25DET 667 lbs (280 hp)
VG30DET 589 lbs
Ford Small Block V-8 487 lbs
Chevy Small Block V-8 575 lbs
Suzuki Sierra: G13BA 73kg
Suzuki Vitara: G16B 89kg
Users browsing this forum: Google [Bot] and 181 guests
