It is currently Mon Nov 09, 2026 10:46 pm
Vehicle: Samurai G16, DMax.
Post Posted: Mon Jan 02, 2012 10:08 pm
Hi Guys. Happy New Year.
I'm still trying to establish whether a T-case for a G16 motor will fit my SV420. I need to get mine overhauled and someone has given me a complete low km G16 gearbox and T-case. Most of the measurements I can take seem to be the same. I'm planning on taking it to a mechanic to do the swap. An e trader up north is telling me they are different and he has the right one for $500. It'll be a bugger plus several days delay if the mechanic hauls mine out and the G16 doesn't fit.
92 Samurai G16
DMax
Post Posted: Mon Jan 02, 2012 10:15 pm
i have one from a g16 in my sv620 only thing differnt is the speedo no longer reads correctly
in saying that you need to make sure its the course spline not the fine like some earlier vitaras
Post Posted: Mon Jan 02, 2012 11:08 pm
That's great news. Thanks for your help.
Steve
92 Samurai G16
DMax
Post Posted: Wed Jan 04, 2012 1:31 am
Back to the drawing board. The T-case I picked up has the wrong splines, my T-case is not so bad and probably not the cause of my worrying "hesitation". I had two mechanics scratching their holidayed heads today. One was certain it is a miss the other not so sure. They put an extra O2 sensor nut on the exhaust and put in a sensor for a test drive. Reading indicated ideally tuned.
Looking at the 1600 gearbox, it has two mount points, the one on the cross member and one on the side. Mine doesn't have a side mount (round one at rear of T-case. Could it be the mount is simply missing and this is causing my vibration/miss which is particularly bad when trying to maintain a steady speed (eg 50 kph in 4th gear)? If you have an SV420 (Gus and Fatzook) could you check or confirm to me that they only have one mount point please?
92 Samurai G16
DMax
Post Posted: Wed Jan 04, 2012 1:58 am
I can tell you fatzooks has a single mount as does my sv620 some of the early 1.6 had the two mounts not sure they all did
Post Posted: Wed Jan 04, 2012 2:00 am
Thanks Tom.
Thought that would be too easy.
Its going to mechanic #4 for another evaluation tomorrow.
92 Samurai G16
DMax
Post Posted: Wed Jan 04, 2012 2:11 am
torque stopper bush is the 2nd transfer mount that the 1.6's use. http://www.ebay.com.au/itm/Torque-Stopp ... 35b27f3d49
i've yet to find a pic of one fitted
Post Posted: Wed Jan 04, 2012 2:21 am
Cheers Gus.
I have one but there's not much use trying to fit it if 1. its not designed for the SV420 and 2. the problem is elsewhere. Desperately clutching at straws but may know more tomorrow afternoon.
92 Samurai G16
DMax
Users browsing this forum: No registered users and 93 guests
