It is currently Thu Aug 06, 2026 10:42 am
Post new topic Reply to topic  [ 46 posts ]  Go to page 1, 2  Next
Post Posted: Fri Jan 06, 2012 4:22 am
ok so this stopped work long ago, figured it was a fuse, now today i started looking, found rear blower fuse, was fine, power both sides, replaced anyway.
then at the rear assembly (fan and ducting) i found a little wierd black fuse thing, so i just bridged it, and it clicked a relay under the fan, but the fan didnt start, am i missing something else?
im just about to put power to the fan and see if it actually works
but the button to enable the rear, just infront of the shifter, doesnt light up when turned on either, like it used to, any help please!
Ryan
Post Posted: Fri Jan 06, 2012 4:36 am
I think that black thing's a resistor.
Have you checked ALL the fuses???
Dropping power in the fan's fine, as long at it's unplugged from the car.....
Post Posted: Fri Jan 06, 2012 4:37 am
all the fuses under the dashm and the 30amp fuse in the bay, i cant find anymore :( i made this thread cos i didnt wanna keep harassing you haha
Post Posted: Fri Jan 06, 2012 4:56 am
Doesn't stop anyone else......
Give the motor 12v & see if it goes, if it does I'd be looking at the switch..
Are there control's in the back??? :?
Post Posted: Fri Jan 06, 2012 5:02 am
yeah on the roof, it used to be tempremental, we would have the roof switch on 100% of the time, and use the button to activate it.
and sometimes it wouldnt work and go more and more tempremental then stopped, maybe the button?
Post Posted: Fri Jan 06, 2012 5:03 am
i cant find 12v at the fan with any of the switches on either so its not even getting power
Post Posted: Fri Jan 06, 2012 5:08 am
eng running with a/c on???
Post Posted: Fri Jan 06, 2012 5:09 am
Try taking it off 100% to.
Post Posted: Fri Jan 06, 2012 5:17 am
yeah just pulled the dash button off, not a single wire there has 12v
car on with front aircon full
no power so im going with a fuse some where or a broken wire?
will pull the roof switch now
Post Posted: Fri Jan 06, 2012 5:21 am
depends how the circuit work's
I'll go did in the bible & see what I come up with...
Post Posted: Fri Jan 06, 2012 5:24 am
whats the 3 relays infront of the battery?
the fuse that says A/C 25A also has a relay attached to it, which some resin is all melted out. what are the other 2 relays, can i unplug one to swap over?
Post Posted: Fri Jan 06, 2012 5:25 am
It has a lil computer to run it, so PLEASE stop bridging stuff.....
you are a king amongst men
Post Posted: Fri Jan 06, 2012 5:26 am
yeah ive only bridged the resistor nothing else. now i wanna swap out what looks like a faulty relay
pic coming now
Post Posted: Fri Jan 06, 2012 5:28 am
It also does self diagnosis, & the only way to check code's is with a Tech2 scan tool...
:helloo: get your wallet out...
Post Posted: Fri Jan 06, 2012 5:30 am
that's a relay......
Post Posted: Fri Jan 06, 2012 5:32 am
yeah it was connected in the front of the battery where im pointing, the fuse says A/C, so i assume its a A/C relay and its all melted, possible cause? is there a relay i can temporarily swap in to test?
Post Posted: Fri Jan 06, 2012 5:35 am
if you don't like that relay go for it......
sound's like the rear blower's drawing to much current, but normally the fuse would blow :?
Post Posted: Fri Jan 06, 2012 5:36 am
nope condenser fan relay, works fine
plugged it in running and it clicked and started the fan
Post Posted: Fri Jan 06, 2012 5:42 am
get a new one, don't like it's chance's of lasting long tho.
Post Posted: Fri Jan 06, 2012 5:48 am
will do, pulled both rear trims, no more fuses, cant find any in the bay. i have no idea :(
Post Posted: Fri Jan 06, 2012 5:51 am
:? I think you lost me 4 post up....
was that relay the condenser fan relay????
Post Posted: Fri Jan 06, 2012 5:56 am
yeah it was,
Post Posted: Fri Jan 06, 2012 5:59 am
Ryan
pic of this please????
do you have 12 on the red wire at the rear blower motor???
Post Posted: Fri Jan 06, 2012 6:09 am
black thing
they are all blue, at the fan is blue and white stripe, and blue and yellow stripe,
yellow a stripe splits into the top of the fan box
white stripe goes to a plug at the tail light
Post Posted: Fri Jan 06, 2012 6:12 am
the click from the black thing being earthed is the valve to allow the aircon gas to flow into the blower from the looks of it
on the last picture where the 2 aircon pipes go in
[quote="[E-Z]
[/quote]
take the 2 screw's out of that & remove, see if you can see any damage
Users browsing this forum: No registered users and 412 guests
