It is currently Sun Nov 08, 2026 4:56 pm
Post Posted: Mon Jan 09, 2012 9:10 am
hey guys
I have a hidden coolant leak. its a g16b motor
Its not the pipe out of back of the water pump or any of the hoses that I can see.
I nearly seems to be coming from under the timing belt cover??
where are the common spots for them to leak?
not I'd normally be the first to say put a pressure tester on It but I dont really need to as its leaking I just cannot see where.
suggestions.
Post Posted: Mon Jan 09, 2012 9:12 am
there is a lot of water pump under the timing cover
Post Posted: Mon Jan 09, 2012 9:24 am
yeah right
its only happening when the system pressurises
so it could well be under the cover, because fucked if I can see where its coming from.
fuck it now I'm going to have to pull the shit box apart again :evil:
only drove it for an hour too
Post Posted: Mon Jan 09, 2012 9:25 am
is it worth putting a gasket on a 85,000km pump??
or just arsehole the pump like my gut feeling
Did you replace water pump?
Post Posted: Mon Jan 09, 2012 9:26 am
i'd ditch the pump and timing belt at those km
Post Posted: Mon Jan 09, 2012 9:27 am
no I didnt touch any of that area.
If I going to pull it all apart I may as well do a tbelt as well
i had a leak on the lower front hose which only appeared under pressure, and it squirted a fine mist of coolant to the back of the block... was looking all over the place before i noticed it when i had my arm in there and my arm got wet! lol
there was no white crusties at all around the leak, which was a pinhole right against the hose clamp.
Post Posted: Mon Jan 09, 2012 9:29 am
no this is somewher I cant see, I'm pretty good at finding shit like that
Post Posted: Mon Jan 09, 2012 10:19 am
I replaced my water pump while engine was in bits.
Was very cheap from the local auto shop.
Forget exact price, but I was suitably surprised.
edit; found reciept
$55 brand new (with a trade/regular discount)
Vehicle: Lwb Sierra
Post Posted: Mon Jan 09, 2012 10:42 am
Stick ya fingers behind the pulley as far as you can go.. there is a drain hole there to let ya know that the seal on the water pump shaft seal has given up the ghost
Users browsing this forum: Google [Bot] and 105 guests
