It is currently Mon Nov 09, 2026 5:11 am
Post new topic Reply to topic  [ 33 posts ]  Go to page Previous  1, 2
Post Posted: Thu Jan 12, 2012 9:36 pm
IN2DEP. I'd suggest dealing with one issue at a time. Find the cause of your current drain before you look at alternator. You need to spend some time investigating.
Vehicle: 93 Sierra
Post Posted: Fri Jan 13, 2012 3:01 am
Just by-the-by it could be your brand new alternator that is the cause, if the battery drain problem has started since it was installed. If one of the diodes in the alternator blows then it'll draw current through the alternator coils even when the car is turned off and parked.
The current draw of an alternator with a blown diode is generally enough that you can generate a spark by having the positive connected and then just touching the negative lead to the battery terminal with everything else switched off. Checking with a multimeter is still the best way though.
Vehicle: 95 Sierra Soft top
Post Posted: Sat Jan 14, 2012 10:43 pm
I always thought that from the start, well im in brisbane for the week so ill will put this thread on hold for now
Users browsing this forum: No registered users and 436 guests
