It is currently Thu Aug 06, 2026 7:37 pm
Post new topic Reply to topic  [ 196 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7  Next
Post Posted: Sat Jan 07, 2012 9:47 am
alien wrote:
run vitara diffs =) 8)
ifs diff with hilux leafs ftw.
:helloo: :D
8) something along the lines of that blue tin top coily "FL33XY" with the brush bars & bushwackers???
8) bang on Gus, I only want 235s and to use it as a daily tho.... Plus I'm pretty sure all of what I've mentioned is still engineerable. Probs not bush wackers, but some neat guards are in the picture for sure.
Post Posted: Sat Jan 07, 2012 9:59 am
Given the "crawly" nature of mentioned tracks will 4.16 be low enough?
Post Posted: Sat Jan 07, 2012 10:02 am
needs rear steer if your only running 235's, might as well go 30's. :?
Post Posted: Sat Jan 07, 2012 10:04 am
Don't encourage him haha.
Post Posted: Sat Jan 07, 2012 10:11 am
needs rear steer if your only running 235's, might as well go 31's. :?
:wink:
Post Posted: Sat Jan 07, 2012 10:17 am
the japs made some good loocking ones too... some like those and other like factory lookcing ones, like the ones of the acid green jimny around here..... and not that expensive tho just like 400$ for the set.... prob is shipping i guess :P
that or just do a chop chop
Post Posted: Sat Jan 07, 2012 10:28 am
:wink:
i heard things don't go to well once you get up to that sort of tyre size? things just break even on a newish one, i read it somewhere on the net. :lol:
a low jim on 30's with a linked front end, geared & locked would be pretty cool.
Post Posted: Sat Jan 07, 2012 10:30 am
:wink:
a low jim on [color=red]chunky /color]30's with a linked front end, geared & locked would be pretty cool.
Would be a very capable machine. But still wont do rope rd. :lol:
Post Posted: Sat Jan 07, 2012 10:38 am
:wink:
a low jim on chunky 30's with a linked front end, geared & locked would be pretty cool.
I got told I wouldn't make it first time I did it.
And the 235's thing shouldn't pose a problem. Didn't on the LWB :lol:
EDIT: http://www.youtube.com/watch?v=J-v1YoFeAv8
Post Posted: Sat Jan 07, 2012 10:52 am
Is there any special flex bushes you can buy?
Thanks :D
Not that i have found :( . My rear's are stuffed already, so i'm looking for other bushes as well, but from what i read on the UK sites the factory bushes are the flexest! Just a shame they don't last that long :?
I asked steve about the rear arms binding up on the chassis mounts and he said to have a look at these to put on the rear radius arm links (can't remember which one now :x should of saved that PM :oops: ).
Post Posted: Sat Jan 07, 2012 10:56 am
Johnny joints. You could always bore out the arms alittle if needed for these to fit in. And if they are bigger than the jim bushes, you could machine in some caster correction.
Rubber Patrol flexxy gu/gq rear bushes are cheap. I got 16 at $20 a pop. Normally $30rrp each. Patrolapart ebay. M14 boltholes though. Can be sleeved for M12 :)
Post Posted: Sat Jan 07, 2012 6:43 pm
Rope Rd can be driven on 235s 8)
The rear end will be linked also gus.
I think that all that's left to do now is to build it.
Will post progress pic's as they happen :D
Vehicle: '78 lj80
Post Posted: Sat Jan 07, 2012 9:21 pm
As for how hard, Rope Rd, secret creek, steps, QLD gate, this new secret track that would have stopped my old lwb ;)
Clearly I take that as a challenge.
ThisIsYourLife&ItsEnding1MinuteAtATime.
Post Posted: Sat Jan 07, 2012 9:44 pm
Your on, can I bumb a lift? Maybe next weekend? You, dan, Joshy cheers and I?
Post Posted: Sat Jan 07, 2012 10:03 pm
this sounds like a fark load of work....
Post Posted: Sat Jan 07, 2012 11:11 pm
It's not a coily so won't be hard at all!
Vehicle: '78 lj80
Post Posted: Sun Jan 08, 2012 12:05 am
Nah, I have 6.5s in my possession now, so they might go in next weekend. And can't drive it to far until I get the steering sorted out at this stage.
But once is all sorted :)
Post Posted: Sun Jan 08, 2012 12:12 am
Nice, you will love the gearing :D
Post Posted: Sun Jan 08, 2012 4:01 am
So are you linking both ends?
Also will you be running F&R sway bar's?
Post Posted: Sun Jan 08, 2012 9:01 am
Yeah I have a collection of 1L, NT & WT sway bars.... So one of them is going to be right-ish.... And yep, linked either end.
Post Posted: Sun Jan 08, 2012 9:05 am
:wink: Still has about 20mm more up travel left in the shock...
Post Posted: Sun Jan 08, 2012 9:48 am
So yours are 4" longer es3000's and they still come pretty close to bumps stops?
Post Posted: Sun Jan 08, 2012 9:51 am
Mine are the 5" ES3000 with shock re-locators.
http://www.jimnybits.co.uk/shop/jimny/j ... rod_5.html :wink:
Tucks up pretty nicely to :)
Post Posted: Sun Jan 08, 2012 4:42 pm
Okay, thanks :D
Post Posted: Sat Jan 14, 2012 3:37 am
One bolt removed, acting allot like a 3link...
Hoping to collect parts across summer and build in the winter :D
Post Posted: Sat Jan 14, 2012 3:39 am
:D
I guess the shocks were way to short? :lol:
Post Posted: Sat Jan 14, 2012 3:54 am
8O
Post Posted: Sat Jan 14, 2012 3:58 am
nice leaning tower of pizza, tyre stack looks safe. 8O
flex isn't too bad either :lol:
Post Posted: Sat Jan 14, 2012 4:12 am
yeah but only short by about 50mm.... can't wait to get it built... maybe i can fit a travel ramp into the build plan :lol:
Users browsing this forum: Google [Bot] and 662 guests
