It is currently Sun Nov 08, 2026 3:03 pm
Post Posted: Sun Jan 15, 2012 1:42 am
Hi all I want to check the timing on my h20a vitara when there is no spark plug leads
Post Posted: Mon Jan 16, 2012 12:09 am
There are two styles of coil pack - 2 wire & 3 wire - based on the number of wires in the connector - early production vehicles have the 2 wire, later have the 3 wire.
I clip my timing light pickup to either one of the two outer wires in the harness leading to the 3 wire coil pack (one is +12v, the other is ground), and you should be able to use either wire with a 2 wire coil pack.
Why do you need to check the timing? It doesn't move unless someone fiddles with it.
Post Posted: Mon Jan 16, 2012 2:46 am
It's extremely down on power and uses loads of fuel
Users browsing this forum: Google [Bot] and 72 guests
