It is currently Sun Nov 08, 2026 2:55 pm
Vehicle: 4 door Vitara G16B Auto
Post Posted: Mon Jan 16, 2012 3:38 am
I bought a LWB Vitara recently in non-going condition (G16B 16V MPFI). I was told the "keyway" was stuffed. Sure enough, the small cambelt drive sprocket on the end of the crankshaft is floating around - This may have been casued by a non existant retaining bolt on the end of the crankshaft - well, the bolt's there, just no head on the bolt - I guess it will come out, or I drill it out.
I'm wondering what my options are here - I want a premanent fix. Here are some possibilities:
1. secondhand crankshaft - where do I get one? How much?
2. re-key the crankshaft shaft on the opposite side (ie. 180 degress out) - problem here is that a new sprocket will probably be just loose enough to casue a problem fairly soon.
3. Sleeve the end of the crankshaft?
Any suggestions?
Post Posted: Mon Jan 16, 2012 3:41 am
Get it welded up and a new keyway machined into it or find a good replacement crank.
Post Posted: Mon Jan 16, 2012 4:21 am
x 2 The above is quite simple for a engine mob. If you can pull it out yourself it will be much cheaper for yourself too.
Post Posted: Mon Jan 16, 2012 5:55 am
I recently had a problem such as this, it was fixed with a speedy sleeve around the crank snout and a hole drilled @ 180 degrees to the allen slot and a grub screw fitted with some thread lock and we have had no problem since.
growing old is nature, growing up is choice.
Post Posted: Mon Jan 16, 2012 7:26 am
Vehicle: 2018 DMAX
Post Posted: Mon Jan 16, 2012 7:39 am
Can get them from suzistore for around $50.
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 75 guests
