It is currently Tue Oct 20, 2026 2:53 pm
Post new topic Reply to topic  [ 43 posts ]  Go to page Previous  1, 2
Vehicle: 2010 Suzuki Swift Sports
Post Posted: Mon Jan 16, 2012 8:38 pm
What grease is recommended when servicing these? I would doubt mine have been serviced ever in the 200k the car has done.
Do you use much of it or just enough to lubricate?
Post Posted: Mon Jan 16, 2012 8:46 pm
As far as I know HTB grease, as per wheel bearings. Don't pack them full, a reasonable wipe on all surfaces is plenty.
Too much grease will jam the hub up.
Post Posted: Mon Jan 16, 2012 9:54 pm
had my avm's for years on locked front with no probs, plenty of snapped axles tho and there still silky smooth no snapped rusty springs for me.
Post Posted: Mon Jan 16, 2012 10:12 pm
I tend to think the snapped rusty springs are more from cars that weren't used off road and therefore the front end wasn't serviced, then bought at 20+ years old and offroaded without looking at the hubs.... until they don't work, then: "aisin hubs are rubbish" my springs snapped hubs are rusty etc.
Some basic maintenance and there's no problem IMHO.
Post Posted: Tue Jan 17, 2012 7:18 am
Warn's need the bolt's tightened on a regular basis, they have no cone washer's,
...Which allows the hub bolts to be upgraded to 3/8" or 10mm, thereby guaranteeing that the next thing that breaks will be expensive/hard to fix trackside, like a Ring & Pinion.
I think there is a case to try Unbrako's with the stock cone washers, or toyota style studs with cone washers though - which can be done with Aisin hubs, but I'm not sure upgrading to 10mm bolts is a good idea.
I'm running unbrako's on my rear floater with no cone washers (drive flanges have no provision for cone washers) and have had no problems with breakage *touches wood*
First I've heard of em.... :?
Do agree with bolt's tho, I like having a weak point...
Vehicle: 85 Suzuki Sierra
Post Posted: Tue Jan 17, 2012 10:54 am
I have had AVMs on my sierra for a few years too with no dramas, i don't break any drive line stuff so i can't comment on how strong they are.
My original ones suffered from the 20 years of no maintenance i suppose and did not unlock/lock all the time which sucked when no-one had a small socket kit when we got to the track and I was rwd only :/.
Someone mentioned the bolts come out?, I think I have had one go missing. I should check them next time I see the zook :).
Orange LWB Sierra
Post Posted: Sun Feb 19, 2012 9:26 pm
Okay need to get new hubs my old Aisins are gone.. been rebuilt a few times and they have had their turn. So looking to buy new set of aisins. Question is are they all the same can I get a Landcruiser set from ebay? Or does some one recommend a good store reasonable price to get a set from ready to bolt up?
Post Posted: Mon Feb 20, 2012 12:04 am
according to this: http://www.aisinaftermarket.com/PDF_Spe ... ceList.pdf they are infact different?
have you seen the price on new aisin hubs though? holy crap!
Vehicle: Suzuki Grand Vitara 04 manual
Post Posted: Sun Jan 07, 2018 9:05 pm
If I get these for an Sq GV, do I need any other parts to fit it? Conical washers etc? Also is this the right part?
https://www.amazon.com/gp/aw/d/B00HFKEF ... 0DER&psc=1
Post Posted: Mon Jan 08, 2018 5:59 am
These are the Sierra version and will require cone washers. If you pull the vitara version from a wrecker where they will be almost free you don’t require the cone washers as they don’t have tapered holes.
Vehicle: 91 Tin Top
Post Posted: Mon Jan 08, 2018 6:45 am
Can I have your wrecker’s phone number?
All the ones in Sydney wanted $120 - $180 a pair when I was looking for a set for my Jimny a few years ago.
Post Posted: Mon Jan 08, 2018 6:50 am
So you can strait swap pre 98 MLH into a post 98 auto hub?.
Post Posted: Mon Jan 08, 2018 7:14 am
300NA- yes.
Pete- we get them from pull-it-yourself wreckers. Pretty cheap.
Users browsing this forum: No registered users and 227 guests
