It is currently Tue Oct 20, 2026 1:40 am
Post Posted: Fri Feb 06, 2009 11:56 pm
Hey all I know this has been covered a million times and I've read all I can find on here and outers and this is what I come up with. As far as I can see to fit WT Diffs into my SWB NT I will have to move spacing of perches inward to NT width, remove WT Flanges and fit NT ones, ditch one of the handbrakes ie;leave the one on the transfer,use WT tie rod and drag link,delete one of the rear brake lines as WT only needs one and then branches out to both sides across diff (may need some bending of lines?) and extend front brake lines for extra width and flex.
Ok is there anything I have left out?
Have you done this Mod? if so advice and pics of your set up welcomed!
I pick my diffs up next weekend from Pubic and would like to get straight into this Mod asap! so all help appreciated thanks in advance. Cheers Robb.
Bitumen...Another waste of public funds!
Post Posted: Sat Feb 07, 2009 12:16 am
you pretty much have it covered mate.
if you want to take it a step further you can fit your NT diff centers for the slightly better ratio.
Post Posted: Sat Feb 07, 2009 12:23 am
Thanks Taff May do that later as I have em but they are welded and I want to use ARB Air Lockers. Cheers Robb
Anyone got picks or know of someone here with a good write up in their build up?
Post Posted: Sat Feb 07, 2009 12:26 am
only other thing i can add is do it one perch at a time. makes it easier to get all the angles right.
Post Posted: Sat Feb 07, 2009 12:57 am
What diff and transfer ratio combo is best for 30-31" Tyres?
Post Posted: Sat Feb 07, 2009 2:13 pm
Depends a lot on the type and frequency of the driving you do.
31's on a DD I'd go 4.9:1 transfer gears and stock 3.7:1 diffs.
If only used as an offroad play toy, go 6.5:1 gears and 3.9:1 (NT diffs) this is what I have and with my 33's which measure 31.5" it's about 10% under stock gearing in high and 197% lower in low. :D
Just found out drag link end been cut on these diffs just need to know if the tie rod ends are the same part and if so are NT and WT the same as I have a few laying around otherwise I'll have to get one here for next weekend thanks Robb.
Post Posted: Sat Feb 07, 2009 2:19 pm
Thanks Jas 6.5:1 gears and 3.9:1 (NT diffs) sound like the go for me as this will mainly be an off road rig not much time on road only to and from the bush. Cheers Robb :wink:
Post Posted: Sat Feb 07, 2009 5:58 pm
NT & WT tie rod ends are different.
WT has a larger diam. threaded section.
Not interchangeable. You'll need a complete WT tie rod with WT rod end.
Post Posted: Sat Feb 07, 2009 7:19 pm
i think damo had some old drag links and tie rods....
Web wheeler extroadinaire
Post Posted: Sat Feb 07, 2009 7:32 pm
I can't help i'm afraid, only have NT stuff.
BTW, I am running 6.1:1 Rockhoppers and 3.9:1 diffs with 32s (measure at 31") and they are OK. 100kph is about 4000rpm.
Post Posted: Tue Feb 10, 2009 5:37 am
Sorry not sure that I explained myself properly the drag link end is the problem, are the WT ones the same part as NT or can I change the WT one to a NT one as WT one has been cut? Cheers Robb. :?
Post Posted: Tue Feb 10, 2009 1:58 pm
NT tie rod is shorter than WT.
NT tie rod end(the removable bit) is smaller thread than WT.
NT drag link(from steering box to tie rod) is shorter than WT.
Drag link ends are not removable.
Jas.
Post Posted: Tue Feb 10, 2009 2:05 pm
Thanks again Jas that's what I needed to know. now I'm on the hunt for a WT Drag link anyone got one? p.s i'll put an add in the Wanted section to! Cheers Robb.
EDIT : PART FOUND THANKS FOR YOUR HELP!!!
Post Posted: Wed Feb 11, 2009 1:37 am
while on the wt diff subject are the axles in an nt able to fit in a wt diff
Post Posted: Wed Feb 11, 2009 1:59 am
As the diffs are wider (the axle's would be too short) so I'd say no go to that one grimreaper others may know of other reasons why :?: Cheers Robb.
Users browsing this forum: Google [Bot] and 198 guests
