It is currently Tue Oct 20, 2026 10:41 pm
Vehicle: 30s front locker barwork
Post Posted: Thu Feb 12, 2009 12:28 am
hey
i was check playin in my wheel bearings today for movement n rembered the guys at suzi sport saying if there is play in the swifle hub when moving the wheels it is the king pin bearings n i had movement so i am just wondering if that information is correct n how do i fix the play can i jst tighten them back up.
Post Posted: Thu Feb 12, 2009 1:01 am
You will have to take the kingpin caps off (4 bolts top and bottom of swivel hub)and remove a shim IF there is any there.
Otherwise it's time for new bearings.
Jas.
thanks
Post Posted: Tue Jul 14, 2009 3:13 am
Howdy All,
Can any one tell me if you need a bearing press of some sort to remove/replace the kingpin bearings from the kingpin? or do they just pull apart.
Ive done this job on my nissan patrol once b4 but never actually removed the bearings from the kingpin and the bearing was well and truly jammed on there, so would this be tha same story on the Jimny's?
Timmo
Post Posted: Tue Jul 14, 2009 12:30 pm
You shouldn't need too much pressure to get the bearing off the kingpin. It's not pressed on there so if it won't come off it may be rusted on there or something like that. I'd try setting the bearing into a vice and carefully hitting the kingpin out with a pin punch.
Post Posted: Wed Jul 15, 2009 12:10 am
Thanks Damo ill give it a go
Users browsing this forum: ProteinDrinker and 217 guests
