It is currently Thu Jul 23, 2026 10:02 am
Post new topic Reply to topic  [ 40 posts ]  Go to page 1, 2  Next
Post Posted: Thu Feb 12, 2009 1:18 pm
There's a bit of talk about tyre pressures in another thread so I thought I'd start this one so noobs can find the relevant info easily in a search.
State your tyre size and road/offroad pressures.
Mine: Sierra LWB
33x10.5-15 Silverstone MT-117 extreme on 15x7" rims
20psi all round ON road
4psi front.. 3psi rear OFF road. (Staun beadlocks)
EDIT: added rim size.
Post Posted: Thu Feb 12, 2009 1:25 pm
31's on 15x8 rims
- 18psi on road
- 8ish off road (if I went off road :roll: )
Post Posted: Thu Feb 12, 2009 1:41 pm
mine: swb sierra
235x75 road tyers on 15x7 rims
20-22 psi on road
and down to 10psi off road
black coily, 30 inch tyers, 2 inch suspention, 2 i
Post Posted: Thu Feb 12, 2009 2:31 pm
235/75 BFG MT on 15x7's
10psi offroad
40 psi on road
Post Posted: Thu Feb 12, 2009 2:44 pm
JrZook wrote:
40 psi on road
8O 8O 8O How does it ride???
Post Posted: Thu Feb 12, 2009 2:54 pm
31s on 15x8 20psi on road and 9 to start with off road.
my last tyres (32s) worked well at 4psi.
i have 235/75/15 with 36 psi
Post Posted: Thu Feb 12, 2009 2:57 pm
the recommended pressure for the standard tyres is 22psi
bigger tyres need less air.
Post Posted: Thu Feb 12, 2009 4:30 pm
ScrawnC wrote:
JrZook wrote:
40 psi on road
Quite well for a sierra actually. OME light duty springs and oil filled adjustable shocks. So much nicer to steer and after 80000ks the tyres are wearing dead flat across the tread.
Dan
Post Posted: Thu Feb 12, 2009 6:37 pm
pretty sure my tires wall says 36psi max
Khumo A/T 235/75/15
Post Posted: Thu Feb 12, 2009 6:51 pm
235/75R15 Wrangler ATR
22psi, 50000km and worn ok except for the inside edge from too much camber and the wobbles from dead struts :), could of done another 30k I reckon
Post Posted: Thu Feb 12, 2009 6:56 pm
hmmmm maybe i need to drop some psi
do you guys go by whats on the tire wall
Post Posted: Thu Feb 12, 2009 6:59 pm
no
Post Posted: Thu Feb 12, 2009 7:04 pm
interesting i want go experiment now :)
but some advice guys
i leave on Monday for my road trip from Perth to Exmouth (3000km round trip)
what psi should i go
not sure if i want to experiment going on a big drive
Post Posted: Thu Feb 12, 2009 7:09 pm
Lots of highway miles requires a little more pressure. I would up the pressure to about 25psi for the big trip. Sierras are too light to have anything more than that in the tyres, I think the tyre placard on the car says 22psi?? 40psi is for Patrols and Landcruisers, not Sierras.
Post Posted: Thu Feb 12, 2009 7:15 pm
i was just going by whats on the tyre wall :( the inflation reccomendation
Post Posted: Thu Feb 12, 2009 7:59 pm
Cade, if you have a full load on your long journey I would suggest around 30-32 PSI for highway speeds
Post Posted: Thu Feb 12, 2009 9:48 pm
22 on road
start at 10 offroad.. unless im just having a play in some dirt then i cbf.
31x10.5 bfg muddies, on SWB vitara.
Post Posted: Thu Feb 12, 2009 10:52 pm
just checked my tyres
they are actually 225/70/15 max pressure 35psi
i just thought that was how much you are menat to inflate too
DOWN she goes :)
run on 32 for the trip to exmouth
Post Posted: Thu Feb 12, 2009 11:50 pm
34" swampers ltb's 6-8 lbs off road 15 lbs on road(rairly on road)
Post Posted: Fri Feb 13, 2009 12:51 am
JrZook wrote:
ScrawnC wrote:
JrZook wrote:
40 psi on road
Dan
people...its not the ride that is important...that is a secondary issue...the most important thing with pressures is braking performance, the higher the pressure, the poorer the braking performance!
as for me with 33's....
max 18 on road....
10 offroad.....(i'm 1.5 ton laoded!...)
Vehicle: 1999 Jimny
Post Posted: Fri Feb 13, 2009 1:42 am
Jesus h christ Joe, where the flying frog fuck did ya dig that bit of gold from????? The Higher the pressure the worse the braking?
Low air pressure will INCREASE bad handling & braking. Out of all the above mentioned pressures If I was on the the tar I'd rather be with Cade or Jnr if something hairy happened.
Vehicle: Nissan
Post Posted: Fri Feb 13, 2009 1:47 am
235/75R15 Wrangler MT/R on my swb sierra i run 25 on 15 off
Post Posted: Fri Feb 13, 2009 1:50 am
higher pressure reduces the amount of rubber on the road, thats why you let your tyres down off road, more traction
less rubber on the road, less grip for braking, less grip for conering.
the only benefit for high pressures is increased sidewall stiffness which helps turn in, but thats easilly fixed with decent suspension settings
too low pressure also cause the sidewalls to flex too much and overheat, a good rule of thumb for fully loaded pressures is you want about a 2psi pressure increase once the tyres are hot, any more and the pressure is too low, or your too overloaded for the tyre (unlikely on a sierra or vitara)
the key here is not higher or lower, its correct, car companies pay engineers big $$$ to sort this crap out, some dude down the tyre shop isnt more correct, plus the load rating on most 4wd tyres could easilly support the entire load with 1 tyre.
Post Posted: Fri Feb 13, 2009 1:56 am
Exactly, if you realise what the LT (light truck) tyres we run are designed for, you'll know why our little zooks only need lower pressures.
Post Posted: Fri Feb 13, 2009 2:45 am
i have only ever run 20 max on the road.
dont see any point going higher. if your worried about handling in a zook with muddies you must be on drugs anyway.
Post Posted: Fri Feb 13, 2009 2:49 am
DOWN she goes :)
Open your door and look at the white sticker on the side of the dash.
The tyre wall says MAX! They are designed to fit a range of cars not just zooks.
I run 20 psi front and 30 psi rear ON road. 30 psi for rear is because of welded diff, makes it a bit easier on tight turns.
8-10 psi off road.
Post Posted: Fri Feb 13, 2009 4:24 am
I run 26-28psi with my 33's..
Under 26psi i can feel the car slowing quicker as the tyres grab the road more.
Over 28psi i can feel the car jolting and bumping all over the place like its on ice.
I run 12psi offroad, Scared of popping a bead...
Post Posted: Fri Feb 13, 2009 6:04 am
we have done the tests............i'm not talking purely off road settings, i'm talking about new tyres, new compund and sidewall, size, volume and vehicle weight. a car has an 'ideal' setting that will see it perform well in all conditions, go above this and braking suffers, go too far below and cornering with speed suffers, etc, etc.measure out a strech of road, than hit the brakes at 40 psi and see how far before you stop, then do the same at 20 psi, you will notice the vehicle stops a bucket load shorter before locking brakes. simple maths....try it yourself....i had to.
Post Posted: Fri Feb 13, 2009 6:08 am
31/15/8 simex et's
22 on road
6 offroad, a hour or 2 later 1 or 2 tyres has 0 in em.
[img]http://www.nbs4x4club.com/forum/files/thumbs/
Users browsing this forum: Google [Bot], Pezooki and 65 guests
