It is currently Thu Aug 06, 2026 1:46 pm
Post Posted: Tue Jan 31, 2012 1:35 pm
as above,i didnt install the motor and it has always run rich, changed all the basics but it is still the same,can someone give me advice
I'm busy,your ugly,have a nice day
Vehicle: 91 Tin Top, 04 Jimny
Post Posted: Tue Jan 31, 2012 1:46 pm
Is this a transplant into a sierra?
Post Posted: Tue Jan 31, 2012 2:10 pm
yep
Post Posted: Tue Jan 31, 2012 2:24 pm
When does it run rich and how have you determined it is rich?
Post Posted: Tue Jan 31, 2012 2:30 pm
only notice it when taking off or at idle
plenty of black smoke
mechenic has looked at it cant find any problems ,he seems to think its a computer problem
Post Posted: Tue Jan 31, 2012 2:31 pm
Have you installed the VSS and O2 sensor?
I'm pretty sure that without these the ECU will run the engine in lean conditions in order to keep it running.
I thought black smoke was burning oil?
Post Posted: Tue Jan 31, 2012 2:39 pm
i had a vitara motor and it had a air flow meter which this motor hasnt got dont no about vss or 02 sensor where do they go
blue smoke is burning oil
Post Posted: Tue Jan 31, 2012 2:56 pm
Not 100% on the baleno engine, but if it's like the vitara engine and came with one stock it should be on your exhaust manifold (if its OBDII there will be one on your cat converter as well).
The VSS is a vehicle speed sensor, which you should be able to read up on, I'm no expert, but from what I know it backs off the fuel when the engine isn't under load.
Here's a link with some info, there's also more in good tech I think.
[http://auszookers.com/forum/viewtopic.php?f=14&t=9978]
This makes the most sense to me, if it's blowing smoke when you're at idle, or after you've been at idle.
Hopefully someone else knows a bit more about this. :?
Post Posted: Tue Jan 31, 2012 3:05 pm
What is it using as the fuel return line? Been a few threads about conversions where people use the stock fuel return and its too small, especially with bigger external pumps so the fuel pressure ends up too high when not a lot of fuel is being used which will make it run rich.
Worth a look.
Post Posted: Tue Jan 31, 2012 4:14 pm
Worth a look.
fuel return runs through standard line so will try that first and let u no
Post Posted: Tue Jan 31, 2012 4:16 pm
check the fuel reg vac line dosent have a hole or crack in it
oil lights are like oven alarms, let u know its co
Users browsing this forum: Google [Bot] and 906 guests
