It is currently Thu Aug 06, 2026 7:32 pm
Post Posted: Tue Jan 31, 2012 7:30 pm
Hey Guys long time no post took a bit of a brake from posting and obsessing about 4wds lol :) anyway atm im in the process of sorting out the front end for the toybuggy on my suzuki SJ70 now my Question is this does anyone know how far fwd they would need to move hilux Diffs to Clear 37s away from the firewall ..
with out actually owning some 37s its a bit hard for me to know im guessing its a 2 inchs..
might see if i can borrow someones tyres so i can work it out just thought someone might know the finger of the top of there head if u do let me know Cheers :)
Post Posted: Tue Jan 31, 2012 8:17 pm
Without a firewall chop i'd say closer to 4".
Post Posted: Tue Jan 31, 2012 8:23 pm
thanks Dan just wanted a rough est i might try get my hands on some 37s do i know for sure
Post Posted: Tue Jan 31, 2012 8:25 pm
this is the diff moved 50mm with no chopping and 33s so i would think that you would need at least another 50mm
Post Posted: Tue Jan 31, 2012 8:28 pm
Around 6 inches depending on tyre width and offset.
Made in JP. Built in WA.
Post Posted: Tue Jan 31, 2012 8:41 pm
This.
Hilux diffs will add scrub radius, which will compound firewall and headlight bucket clearance issues.
Hmm might need to look into Fire wall chops unless i want a stupid big Chassie Extension lol
Post Posted: Tue Jan 31, 2012 8:43 pm
Coil it instead then..
Post Posted: Tue Jan 31, 2012 8:48 pm
$ problem easyer to Leaf spring it for now il work it out :) not to worry :) nothing a Big hammer and grinder cant fix
Post Posted: Tue Jan 31, 2012 9:14 pm
What springs do you plan on using ? Lux fronts would be good for a smallish chassis extension.
Post Posted: Tue Jan 31, 2012 9:18 pm
to be honest i have not really put much thought into it i was thinking some lux Fronts i do have a few sets of springs laying around including some old rodeo rears s its a case of trail and error i think but most likely lux springs
Post Posted: Tue Jan 31, 2012 9:27 pm
I think Alien has said his front diff is around 6 inches forward on Lux fronts.
Post Posted: Tue Jan 31, 2012 9:44 pm
well that might do the trick then il see if i can get my hand on some thanks red :)
Post Posted: Tue Jan 31, 2012 9:50 pm
Ive added 3" forward for 35x12.5r15 on 15x8-19 on hilux front diff. (coiled)
If i want 37's on same rims, might have to hammer the firewall abit. So about 5" would be nice.
Users browsing this forum: No registered users and 654 guests
