It is currently Thu Aug 06, 2026 7:36 pm
Post Posted: Tue Jan 31, 2012 2:04 pm
any one else have issues with slightly rich???
mine occasionally has a fuel smell (no leaks that i can find) and uses slightly more fuel that i would expect 9-10L/100km??
where should i start?
Phil
Post Posted: Tue Jan 31, 2012 3:26 pm
My m13a vvt has been using lots of fuel Lately and you can some times smell petrol when its idling. Turns out my Egr valve was fuked. It got fixed today....not sure how you would check the Egr valve tho...
Post Posted: Tue Jan 31, 2012 4:45 pm
I go through half a tank in two days :(
Post Posted: Tue Jan 31, 2012 5:31 pm
how many km's? i get OK mileage..
my fuel usage doesn't seem to change if i am going easy or giving it a bit of a hard time
Vehicle: Suzuki Jimny 2010
Post Posted: Tue Jan 31, 2012 5:36 pm
I'm getting about 8.7l/100kms around town etc, but 10ish fully loaded or wheeling. Mines VVT though.
Post Posted: Tue Jan 31, 2012 6:16 pm
Roughly 130Km
Vehicle: 2011 Jimny
Post Posted: Tue Jan 31, 2012 6:19 pm
zooky08 wrote:
Roughly 130Km
WTF !!!!!
im getting 450 if i drive normal or 530 if i baby it
Jimny's really do ROCK
Post Posted: Tue Jan 31, 2012 6:28 pm
Mine drinks it like a thirsty camel even if I be sensible. I fill up every 4 or 5 days.
Vehicle: 2011 Jimny
Post Posted: Tue Jan 31, 2012 6:32 pm
when was last time you cleaned air filter, checked spark plugs, etc
not being a smart arse but 130km just doesn't sound right.
Post Posted: Tue Jan 31, 2012 6:35 pm
New aircleaner was put in a month ago. Not sure about spart plugs. Most I have got out off a tank would be 350km
Vehicle: 2011 Jimny
Post Posted: Tue Jan 31, 2012 6:44 pm
http://www.gnttype.org/techarea/engine/plugs.html
have a look at your plugs when you get a chance
also may have a to look into you oxygen sensor (O2 sensor) if that is gummed up with shit or its starting to die then that may also cause some issues
(if im wrong please correct me)
Post Posted: Tue Jan 31, 2012 8:26 pm
I'm lucky to get about 300kms around town. (and I try to baby it) I can't smell fuel...seems like everything is ok. Perhaps not. :-(
(2010 1.3VVT)
 Profile YIM
Post Posted: Tue Jan 31, 2012 9:06 pm
(2010 1.3VVT)
235's will do that tho :wink: these guys are running 215's...
Post Posted: Wed Feb 01, 2012 1:57 am
I'm getting about 300kms from 235s and stock gearing. I drive pretty slow tho....
Was about 400-500kms with roadies on.
Post Posted: Wed Feb 01, 2012 6:02 am
maby its about right then?
Post Posted: Wed Feb 01, 2012 6:18 am
woo603 wrote:
WTF !!!!!
tha fuck! 8O r u two vvt???
mine with 215s i only get 300-350 .... even when have stock tyres was pretty much the same
Post Posted: Wed Feb 01, 2012 7:33 am
speedos are rarely accurate,
especially with taller tyres,
so you may be getting better economy than you think.
But yes, raise body position adds wind drag,
and taller tyres add weight and rolling resistance.
Off road capable cars will never be road warriors.
Post Posted: Wed Feb 01, 2012 7:40 am
Nope G13bb all the way :D
Post Posted: Wed Feb 01, 2012 9:20 am
with roof rails. :lol:
It was pretty good on petrol. Better than my sierra!
Post Posted: Wed Feb 01, 2012 9:56 am
Are you guys that are worried about your apparent crap fuel economy correcting your odometer readings for the larger tires before working out km/L?
Lil Foot!
Post Posted: Wed Feb 01, 2012 10:02 am
I'm none vvt as well, but my car is 20 foot in the air so I have wind drag like Chris said
My fuel economy is heaps good offroad though
I can do a day worth of 4wd and the gauge doesn't move much.
I sit at 4100rpm at 100ks. Jimny like to rev.
I'm trying to lower my rpm. 3900 would be good I reckon.
Post Posted: Wed Feb 01, 2012 11:22 am
I know all that.. we re talking bout the reading of the speedos without correction.... and we having same kind of tyres they re getting far more than me
and I only have 45mm lift, so is not really that much
and like I said, when I was stock (suspension and tyres -205/70/15) I still have the same-ish crappy fuel eq (300-350km)
not worry bout that, Im worry bout how come they can get 400-500km ?????....... I get the gauge till the red mark.... prob ill still have an extra 5-8lt in the tank on that point, but still
Post Posted: Wed Feb 01, 2012 11:53 am
my figures are tps corrected
Post Posted: Wed Feb 01, 2012 12:08 pm
Ah yeah! It's all in the roof rails :lol:
My speedo is about 5kms out....
Post Posted: Wed Feb 01, 2012 1:09 pm
Mine just has the 80mm TD springs/shocks and 235's so not overly high.
 Profile YIM
Post Posted: Wed Feb 01, 2012 2:17 pm
Before I added all the shit I've added in the last 12 months, mine easily did 450kms not babying it! I reckon I could have gotten 500+ out of it back then. Did a trip to VIC for new years, and fully loaded with swag, and a bit of stuff on the roof, I got around 10.5l/100kms, at round 35l of juice per fill...350ishkms give or take. Thats also with a bullbar,winch, 40mm lift and like I previously mentioned all the gear on the roof!
Bert, you're climate may play a little role in yours (heat and humidity etc) but I wouldnt guess that much, but Phil, you definitley have something wrong if you can smell the rich fuelly smell!
Post Posted: Wed Feb 01, 2012 2:35 pm
Dude if you really think about it, if you had even 5 useable liters left in the tank and using around 1L per 10kms, that's an extra 50k's added onto your 300-350.
If you really want to check your actual fuel economy accurately go to the servo, reset your tripmeter, fill the tank so its absolutely full ie not to just when the nozzle stops but when you actually can see the fuel level at the filler neck, go use your car till nearly empty, then go back to the servo and re-fuel till its absolutely full like before. Record the tripmeter k's and divide by how many liters the car actually used.
Lil Foot!
Users browsing this forum: No registered users and 648 guests
