| Author |
Message |
dougies_tx5turbo
Joined: Tue May 25, 2010 10:56 am Posts: 1051 Location: north brisbane
 Posted: Sat Dec 31, 2011 1:36 am |
All sold  photo for some of the parts are here http://s1199.photobucket.com/albums/aa4 ... 1QQtppZZ24NT rear axles with new wheel bearings and brake drum assembly with new brake pads, missing the one master cylinder need them gone as one whole piece as I don’t want the bearings to get wrecked by water damage. Make offers.$65 repco rear diff seals new $10 for the pair monza window winder used $15 for the pair 3x hardtop side windows $10 Rear Window with rubber for hard top rear door without demister good for when doing ute conversion $10 NT seat mounts the ones that fold forwards good for utes x2 $10each Pedal box $5 toyota 4y carbys x2 off a toyota hilux 1985 they well need a good clean and a carby kit put in them $50ono for both of them Yamaha yz125h 1981 first of the water cooled 125cc $1200ono 4ft fish tank used as a reptile cage $60 alot of baby stuff will list soon suzuki sierra 1L bonnet with a hole cut into it $5 2x rear hard top door hinges $5 2x Behind steering wheel cover $5 each 3x front indicator brackets $2 3x side indicator brackets $free 1x reverse light cover $2 2x brake light and indicator covers $free 1x side indicator cover $3 sold pending payment2x bonnet releases cable $5 Driver’s seat rails $10 1x brand new door handle $15 1x brand new window winder $5 Hard top roof head liner bar $2 handbrake leaver $5 Pastor shelf $5 Container full of body rubbers Container full of shock and suspension rubbers $5 1L airbox top lid $5 3x hard top roof handle bar $2 for all Suzuki bonnet badge $5 5 speed badge $10 2x sierra 1.3 badge $10 2x small Suzuki badge $3each front brake lines $5 2x clutch cable $10 steering dampers standard $5 The bonnet stick that holds up the bonnet $5 Maybe 20 times original plastic clips that hold the door cards on $3 1L heater box fire wall rubber $2 A container full of body bungs A container full of body bungs with holes for wires to run through them I will swap for a good air compresor,air compresor hose.
Everything I am negotiable on. Need money for my jimny brisbane north side Strathpine
Last edited by dougies_tx5turbo on Tue Nov 25, 2014 12:52 am, edited 58 times in total.
gvzookdriver
Joined: Mon Apr 13, 2009 11:30 pm Posts: 1833 Location: Brisbane
Vehicle: Sold zuk got a Bt50
 Posted: Sat Dec 31, 2011 7:09 am |
do you have a 3 into 2 brake block
_________________ bt50 now but still love the zooks
dougies_tx5turbo
 Posted: Sat Dec 31, 2011 7:21 am |
gvzookdriver wrote: do you have a 3 into 2 brake block
no it went with the chassis
gvzookdriver
 Posted: Sat Dec 31, 2011 7:36 am |
ok thanks
remydog05
Joined: Sun Nov 23, 2008 10:30 pm Posts: 1260 Location: Vic
 Posted: Sat Dec 31, 2011 8:49 am |
im out on a limb i know but 1.3 starter motor?
bazuky
Joined: Sun Jan 16, 2011 11:01 am Posts: 4 Location: brisbae
 Posted: Sat Dec 31, 2011 9:01 am |
dougies_tx5turbo
 Posted: Sat Dec 31, 2011 9:38 am |
remydog05 wrote: im out on a limb i know but 1.3 starter motor? no dont have one
MUD-PIG
Joined: Wed Apr 02, 2008 10:30 pm Posts: 1941 Location: Darwin N.T
 Posted: Sat Dec 31, 2011 11:44 pm |
Interested in your tyre bracket for the back door, will you post it up to Darwin for me..??
How is its condition..?
dougies_tx5turbo
 Posted: Sun Jan 01, 2012 3:45 am |
MUD-PIG wrote: Interested in your tyre bracket for the back door, will you post it up to Darwin for me..??
yes i will post it. its in good condition i can get a picture up on tuesday night. i will find the weight out my post code is 4500.
MUD-PIG
 Posted: Sun Jan 01, 2012 10:01 am |
dougies_tx5turbo
 Posted: Sat Jan 07, 2012 1:00 am |
bump.
Last edited by dougies_tx5turbo on Mon Apr 02, 2012 5:55 pm, edited 1 time in total.
dougies_tx5turbo
 Posted: Thu Feb 02, 2012 4:33 pm |
bump
Last edited by dougies_tx5turbo on Tue May 14, 2013 2:47 pm, edited 2 times in total.
Ruthless
Joined: Tue Jan 11, 2011 8:50 am Posts: 1049 Location: Brisvagas
 Posted: Thu Feb 02, 2012 5:53 pm |
the body rubbers which bit are they if they if they ones that are about 20mm thick and go under the car ill take them
_________________ rust is lighter then carbon fiber
dougies_tx5turbo
 Posted: Thu Feb 02, 2012 5:59 pm |
Ruthless wrote: the body rubbers which bit are they if they if they ones that are about 20mm thick and go under the car ill take them will check but I am sure i have some, pm when you what to get them
boost=money
Joined: Sun Aug 16, 2009 11:30 pm Posts: 240 Location: brisbane
 Posted: Thu Feb 02, 2012 8:34 pm |
Hey mate im chasing wt standard body blocks and bolts do u have any of this? removing body lift and dont have standard stuff
dougies_tx5turbo
 Posted: Thu Feb 02, 2012 8:51 pm |
the bolts should be still on your body there is alot of square body rubbers I will check
Teracis
Joined: Sat Dec 11, 2010 10:03 pm Posts: 2261 Location: Gold Coast
Vehicle: Daisy
 Posted: Thu Feb 02, 2012 9:07 pm |
Hey mate, what condition is the drivers seat rail in? as well as the side indicator lens?
If they are good condition and will suit a WT, I'd like them both, I'm only on the gold coast but I'll pm you tomorrow to get details if they are in good condition.
dougies_tx5turbo
 Posted: Thu Feb 02, 2012 9:21 pm |
Teracis wrote: Hey mate, what condition is the drivers seat rail in? as well as the side indicator lens?
If they are good condition and will suit a WT, I'd like them both, I'm only on the gold coast but I'll pm you tomorrow to get details if they are in good condition. drivers seat rails are in good condition, the lever side had a crack but has now been welded up and does not affect it. indicator lens is not cracked just needs a good scrub.
Teracis
Vehicle: Daisy
 Posted: Fri Feb 03, 2012 5:45 am |
dougies_tx5turbo wrote: Teracis wrote: Hey mate, what condition is the drivers seat rail in? as well as the side indicator lens?
If they are good condition and will suit a WT, I'd like them both, I'm only on the gold coast but I'll pm you tomorrow to get details if they are in good condition. drivers seat rails are in good condition, the lever side had a crack but has now been welded up and does not affect it. indicator lens is not cracked just needs a good scrub. Ah well that's the same condition as mine, so don't worry about the rail, I wouldn't mind the indicator lens, any chance of post to gold coast? We are talking about the one that goes above the wheel arch right?
dougies_tx5turbo
 Posted: Fri Feb 03, 2012 1:36 pm |
Teracis wrote: dougies_tx5turbo wrote: Teracis wrote: Hey mate, what condition is the drivers seat rail in? as well as the side indicator lens?
If they are good condition and will suit a WT, I'd like them both, I'm only on the gold coast but I'll pm you tomorrow to get details if they are in good condition. drivers seat rails are in good condition, the lever side had a crack but has now been welded up and does not affect it. indicator lens is not cracked just needs a good scrub. Ah well that's the same condition as mine, so don't worry about the rail, I wouldn't mind the indicator lens, any chance of post to gold coast? We are talking about the one that goes above the wheel arch right? mate put pic up of the lense and there is a bit of a scrape off the top as you can see in the photo, should be able to put in an envelope and post.pm me if your keen.
hobble
Joined: Tue Jul 05, 2011 10:52 pm Posts: 52 Location: brisbane
 Posted: Fri Feb 03, 2012 10:53 pm |
hi mate how much tread is left on the tyres thanks
dougies_tx5turbo
 Posted: Sun Feb 05, 2012 11:45 am |
hobble wrote: hi mate how much tread is left on the tyres thanks thanks bud for buying the tyre's made my day
jim_dover
Joined: Fri Sep 11, 2009 11:30 pm Posts: 286 Location: Brisbane
Vehicle: '84 LWB 1LTR
 Posted: Tue Feb 07, 2012 1:54 pm |
Hi mate I can be over thursday night to grab the stuff below if you still have it.
Cheers Nick
1L starter motor unknown condition $5
1L alternator unknown condition $5
1L 4 speed knob $5
1L tail lights $free
Brake booster $free
1L engine mount and bracket $10
2x door straps $5
1L acceleration pedal $3
Acceleration cable, good for a spare $5
6x 1L rubbers that go behind the 1L head light covers $2
2x 1L heater box fire wall rubber $2
1L steering columns $15
_________________ '86 SWB SIERRA 1.6EFI, '84 LWB SIERRA 1.0LTR
dougies_tx5turbo
 Posted: Tue Feb 07, 2012 9:26 pm |
mroy
Vehicle: sierra
 Posted: Wed Feb 08, 2012 1:12 pm |
hi, im interested in the rear diff housing, do you still have it? would i be able to come and have a look
dougies_tx5turbo
 Posted: Mon Feb 13, 2012 5:14 pm |
GRPABT1
Joined: Mon Nov 19, 2007 10:30 pm Posts: 731 Location: Townsville
 Posted: Mon Feb 13, 2012 7:34 pm |
Interested in a set of door hinges. Can you get a Price for postage to 4812?
dougies_tx5turbo
 Posted: Mon Mar 19, 2012 1:38 pm |
Toyzuka
Vehicle: 1991 SJ70
 Posted: Wed Mar 21, 2012 8:39 pm |
dougies_tx5turbo
 Posted: Wed Mar 21, 2012 8:58 pm |
everything that is listed and some other little random bits. i take them off the list when something is sold, so people know whats left.
