It is currently Sun Nov 08, 2026 1:32 pm
Vehicle: yellow 83 sierra
Post Posted: Thu Feb 09, 2012 8:11 am
Hi i was wondering what power steering upgrade is there for vitara's that are going to be running 35's?
Post Posted: Thu Feb 09, 2012 9:09 am
35's on a Vit & still IFS? :?
Post Posted: Thu Feb 09, 2012 9:13 am
What is IFS?
Post Posted: Thu Feb 09, 2012 10:06 am
IFS = Independent Front Suspension
Post Posted: Thu Feb 09, 2012 11:33 am
Nah live front end
Post Posted: Thu Feb 09, 2012 11:37 am
Hydro
Post Posted: Thu Feb 09, 2012 2:41 pm
Please explain more?
Post Posted: Thu Feb 09, 2012 2:54 pm
Get a new pump and cooler from low range
If that's not enough get the box taped for hydro
It's where u use a ram from the diff to the drag link to help push it around
Or get the new pump and a box from another car
Finding one to fit is the problem
Post Posted: Thu Feb 09, 2012 6:20 pm
A Vitara box will turn 35's fine with a hot rodded pump. The biggest problem is that your steering is going to get [i]SLOOOOW/i]
Pay carful attention to pitman arm length vs steering arm length to avoid this.
If this gets too hard, the premium upgrade would be a LHD IFS hilux box.
I don't know how many people have experience with hydro assist on a road-driven car, but the research I have done indicates it does slow the steering down a bit. That would drive me mad, especially in a car that already had too-slow steering because of a mismatch between pitman arm length and steering arm length. I was pretty keen to try hydro assist but the loss of speed that I've heard is the norm wouldn't be acceptable for me. I like to carry some speed on fast dirt and slow steering is unacceptable.
Post Posted: Sat Feb 11, 2012 8:45 pm
Why LHD Lux Steve? They get upgrades in the states? Question is how much else needs to be sourced/fabbed/modded to get it in...
Anyone know of anything a bit easier/cheaper to find? Other than the LROR $200 pump, $45 pulley, $50 bracket, $40 reservoir, $130ish of plumbing, $60 cooler, $135 for a beefier arm, $35 bracket... what's that, nearly $700 That's not actually that bad...
Hydro sounds horribly inefficient to me, but I can't claim to have researched it much.
Post Posted: Sat Feb 11, 2012 10:10 pm
DarkHorse wrote:
Why LHD Lux Steve?
I think it is to do with fitting box on inside of chassis.
I think? hi lux is mounted outside?
This could all be BS, but sounds feasible
Post Posted: Sat Feb 11, 2012 10:12 pm
christover1 wrote:
DarkHorse wrote:
Why LHD Lux Steve?
Spot on.
It sits on the outer side of the left rail in LHD format. This is perfect for fitting to the inside of the right hand rail for RHD.
Post Posted: Sun Feb 12, 2012 2:56 pm
oh ok thanks guys for your help i might just have a read about what there is to do if i just upgrade the power steering pump to the original box would that be good enough?
Post Posted: Sun Feb 12, 2012 3:06 pm
I thought an IFS lux had an inner chassis mounted box also.
Post Posted: Sun Feb 12, 2012 3:19 pm
Nope:
That's a LHD IFS box on a SAS swapped hilux.
Post Posted: Sun Feb 12, 2012 4:29 pm
:O that looks like the way to go but where over here would i be able to get one do they have them down in vic?
Post Posted: Sun Feb 12, 2012 4:59 pm
Depending on the track width of the axle you are going to be running in the front, along with tyre size and rim offset, you might no need a LHD IFS hilux box - a RHD box might be fine.
LHD boxes are available from Trail Gear or Lowrange.
http://www.lowrangeoffroad.com/index.ph ... boxes.html
Post Posted: Sun Feb 12, 2012 7:04 pm
i think that i might be right about steering boxes i might be able to use the rhd as i think there should be plent of room to bolt it up be more the fact that it might get close to the engine i duno yet one thing at a time ay
Users browsing this forum: Google [Bot] and 82 guests
