| Author |
Message |
jim_dover
Joined: Fri Sep 11, 2009 11:30 pm Posts: 286 Location: Brisbane
Vehicle: '84 LWB 1LTR
 Posted: Fri Feb 10, 2012 1:56 pm |
Hi everyone I recently purchased a 1LTR '84 LWB sierra. And I have decided to part out my SWB NT. I am wondering if the spartan locker that is currently fit in my SWB will be able to transfer into the rear of the LWB? I was told that the LWB has been upgraded to 93? model LWB diffs as they have larger rear drums? Not sure if this will make a difference.
Any in put would be much appreciated!
_________________ '86 SWB SIERRA 1.6EFI, '84 LWB SIERRA 1.0LTR
Fatzook
 Posted: Fri Feb 10, 2012 2:23 pm |
Hard to say. 93 model LWB is most likely a NT Maruti, so the diffs will be smaller than your SWB diffs.
Can you get pics?
jim_dover
 Posted: Tue Feb 14, 2012 8:54 pm |
I can put some pics up. What do you want me to take photos of?
Fatzook
 Posted: Tue Feb 14, 2012 9:01 pm |
jim_dover wrote: I can put some pics up. What do you want me to take photos of? The whole car, and just the diff housings.
2stroker
Joined: Sun Sep 07, 2008 11:30 pm Posts: 2689 Location: North Brisbane
 Posted: Wed Feb 15, 2012 7:14 am |
The way I understand this is that your original veh is a 1litre swb and you have bought a 1litre lwb fitted with 1993 diffs. If this is the case and it is still NT then it must have maruti diffs which are same size as 1300 NT except that they are 4.1 ratio. So your old centres will not fit they will be too small.
Fatzook
 Posted: Wed Feb 15, 2012 8:27 am |
2stroker wrote: The way I understand this is that your original veh is a 1litre swb and you have bought a 1litre lwb fitted with 1993 diffs. If this is the case and it is still NT then it must have maruti diffs which are same size as 1300 NT except that they are 4.1 ratio. So your old centres will not fit they will be too small. Sorry Kas but I have to disagree there mate. Maruti diffs post 94 ARE 1.3L size. All pre-94 are 1L size and ratio. He says the diffs are from a 93 LWB which ( unless they are from the uber-rare WT LWB) are 1L diffs.
jim_dover
 Posted: Wed Feb 15, 2012 5:11 pm |
Thanks for the in put guys. I have put photos up on the rigs of auszookers thread viewtopic.php?f=4&t=30501There is some photos there of both the car and the diffs hope this helps with my question? cheers
Fatzook
 Posted: Wed Feb 15, 2012 7:55 pm |
Answer = No.
Your 86 NT Diff centres/ lockers are too big to fit into the 84 NT 1L housings.
BUT! You could straight swap the NT diffs into the 1L. Youll just need to sort out drive shafts and possibly rear brake line. ( can't remember) .
cairns27
Joined: Thu Dec 23, 2010 7:42 pm Posts: 489 Location: Macleay Island
 Posted: Wed Feb 15, 2012 8:14 pm |
I've learnt the hard way,NT LWB centres won't fit into a NT SWB diff housing.
bye
want33s
Joined: Fri Nov 16, 2007 10:30 pm Posts: 8134 Location: Sunshine Coast Qld
 Posted: Wed Feb 15, 2012 8:25 pm |
cairns27 wrote: I've learnt the hard way,NT LWB centres won't fit into a NT SWB diff housing.
bye Really? SWB and LWB 1.3 diffs are identical..... 1.0 diff housings and centres are different to 1.3 but again, swb and lwb 1.0's all share the same diff housings and centres.
cairns27
 Posted: Wed Feb 15, 2012 8:40 pm |
want33 Ive got a 89 NT LWB 1.3.
I sold a wrecked NT SWB drover to Ben off this site, and he gave me a NT SWB housing he had ,spent a day cleaning and painting the dash thing;fitted it the next day..... centre wa too big.
bye
want33s
 Posted: Thu Feb 16, 2012 8:34 pm |
cairns27 wrote: want33 Ive got a 89 NT LWB 1.3.
bye Drovers are all 1.3. If a 1.3 centre didn't fit the housing you got it's because it is a 1.0 housing.
cairns27
 Posted: Thu Feb 16, 2012 8:57 pm |
Mine's stock, previously owned by a little old lady.
bye
want33s
 Posted: Fri Feb 17, 2012 7:07 am |
89 NT 1.3 LWB Really? That'd be good except Suzuki stopped making them in 88.
BlueSuzy
 Posted: Fri Feb 17, 2012 7:50 am |
88 swb/lwb went WT. 1.3 diffs. NT flanges
cairns27
 Posted: Fri Feb 17, 2012 5:17 pm |
Yea mine's a bit different, I think it's fully imported.
I seen others with my dodgy longrange tank setup, DOT didn,t know what 3rd party I had to have.
In the end we called it a soft top station wagon.
bye
want33s
 Posted: Fri Feb 17, 2012 7:55 pm |
cairns27 wrote: Yea mine's a bit different, I think it's fully imported.
bye Yellow LWB with a LR tank..... I bet yours is EX Qld railways.
303zuke
 Posted: Tue Feb 21, 2012 12:18 am |
bye Every single Suzuki product in Australia (Car, Bike 4wd, Outboard, Generator, Lawn Mower) IS FULLY IMPORTED! None of them are made in Australia
cairns27
 Posted: Tue Feb 21, 2012 5:12 am |
Well if want33 is correct, QGR must have had a special lot imported.
bye
Fatzook
 Posted: Tue Feb 21, 2012 11:27 am |
cairns27 wrote: Well if want33 is correct, QGR must have had a special lot imported.
bye I don't believe so. They were all modified locally before delivery to QR.
