It is currently Mon Apr 27, 2026 9:41 pm
Post Posted: Wed Feb 25, 2009 1:06 am
Going through some sierra vids on youtube and i came across this one. Just wondering if this actually does work and if it's worth it?
http://www.youtube.com/watch?v=Bk-W4EMvsBM
Vehicle: 1995 Sierra 1.3
Post Posted: Wed Feb 25, 2009 2:13 am
One of the Guys from Outer's did that video. There's a thread about it on outers also.
Post Posted: Wed Feb 25, 2009 3:46 am
do you have a link to it 'lokidog', i couldnt see it anywhere there.
79' LJ80 (sold) :(
95' & 97' sierra (sold)
Post Posted: Wed Feb 25, 2009 5:22 am
http://www.outerlimits4x4.com/sutra1527 ... t=#1527983
Page 3 of the thread. Post was made by Rockhopper.
91 1298cc Sierra, 31 x 10.5 mud terrain tyres, 6.5:1 tranfer case gears, and everything else is pretty much standard. Was struggling to get 110km/h before I ran a t-peice off the vacuum advance hose to the secondary actuator diaphram, but now it will easily get to 110km/h and I've actually had it up to just over 130km/h on a nice flat peice of freeway.
Post Posted: Wed Feb 25, 2009 12:10 pm
free sticker to anyone that can give a convincing reason why thats a useful mod and not a placebo!!!!!!!!!!!!!!!!!
the whole idea of vac secondries is they only open when the primary cant supply anymore air, it keeps your fuel metering correct and the throttle easy to control, the correct vacuum advance port is designed to have high vacuum at times of low load so you get more spark advance at cruise to help with economy, its nothing to do with power!!!!!!!
so this thing is opening at high manifold vacuum and low throttle (as seen by free revving it in the vid) when there probably isnt enough airspeed through both barrels to suck fuel out probably causing it to run lean (which I am guessing a stuffed carby combined with all the vacuum hoses being ass about and the carb put back together wrong by backyard mechanics that dont pay attention) is compensating for some other fault.
Post Posted: Wed Feb 25, 2009 1:46 pm
As said before on another subject 'HiClones'…
If this works correctly, why don't the manufacturers do it when building the car? Always a bit suss with mod's like this!
Can I please have a sticker anyway? :wink:
Post Posted: Wed Feb 25, 2009 1:48 pm
Lokidog wrote:
http://www.outerlimits4x4.com/sutra1527983.php&highlight=#1527983
Oh, and I can get my 1.3 up to 130kph as well without this particular modification :D
Post Posted: Wed Feb 25, 2009 1:49 pm
What's a placebo??? I thought it was a band :? :lol:
Post Posted: Wed Feb 25, 2009 1:55 pm
Placebo = Snake Oil that works only because the person using it want's it to work.
Post Posted: Wed Feb 25, 2009 2:21 pm
Yup, I know :roll: Good description by the way.
Post Posted: Thu Feb 26, 2009 11:01 am
Yes, I posted the vid on youtube and yes it does work if you are haveing problems with the vacuum operated secondary's opening, as I did when I bought the car. If the secondary's currently work fine, then it will make little differance to how it runs. Because I was having problems with my secondary's opening I was barely able to crack 100km/h on the freeway. After doing this mod I was able to get 130km/h on the freeway. It did'nt use any more fuel than normal either.
The carby's never been apart, and the vaccum hoses have never been mucked around with. After filming this video, when I got the time to check it out properly, I found that the original vaccum hose to the secondary's had somehow become restricted and was why the secondary's were'nt opening correctly. I have since returned the vacuum hose configuration to standard and the car still pulls 130km/h down the freeway. Happy days. :D
Post Posted: Fri Feb 27, 2009 2:31 am
Rockhopper gets the sticker :D
Post Posted: Fri Feb 27, 2009 10:42 am
WOOHOO!!
Post Posted: Fri Feb 27, 2009 3:27 pm
i had an issue with my secondarys and when replacing the vaccum hoses one was restricted, by a ball bearing! nfi how it got there.. but yeh worth checking your hoses first.
Post Posted: Fri Feb 27, 2009 9:00 pm
No idea what was restricting mine, but it had me stuffed for a while. When I bought the car I was the 3rd owner and I had the full service history from when the car was new and it was always serviced at Suzuki. Only thing I can think of, is some bright spark at the dealership might have sealed the hose to stop the pinging problem that is all too common on the 1.3's when they carbon up. Another reason not to trust dealers :evil:
Post Posted: Sun Mar 01, 2009 2:31 pm
[quote][i]91 1298cc Sierra, 31 x 10.5 mud terrain tyres, 6.5:1 tranfer case gears, and everything else is pretty much standard. quote]
just wondering how much have the tyres put ur speedo out
Post Posted: Sun Mar 01, 2009 5:28 pm
Speedo reads a touch over 90 when I'm actually doing 110km/h. Am currently trying to organize a day off at work so I can have it recalibrated. It's about a 15km/h differance
Users browsing this forum: No registered users and 35 guests
