It is currently Thu Jul 23, 2026 1:40 pm
Post new topic Reply to topic  [ 35 posts ]  Go to page 1, 2  Next
Post Posted: Tue Feb 24, 2009 7:42 pm
has anyone done this and how have they done it.
reason is i am spoa with a 2inch bodylift 8O
navara on 33s. hopfully rear air locker soon
Post Posted: Tue Feb 24, 2009 7:51 pm
Yes, it can be done. Damo did it, check out his thread. Are you taking the body lift out?
Post Posted: Tue Feb 24, 2009 10:04 pm
yer i want to take the bodylift out. it acelly had a 3inch bodylift i have got no ider why sumone would but a 3inch bodylift in. i then put in a 2inch to lower it a bit. the bonnet now is just hitting the airbox. going down a nother 2inch its not gana work.
i am just seeing what my options are and as a last resort i will take the engine out but i do not want to do that too much shit to do
Post Posted: Tue Feb 24, 2009 11:22 pm
I had 2 inch body lift. I removed and don't regret it. I have 1.6 carby engine which is higher than EFI, but I may be wrong. It doesn't fit under the bonnet. I had original vitara air filter, big nearly as half of the bonnet. I replaced it with siera air intake and air box, got my friend grinder and cut the bonnet and made a scoop. Some people raise the bonnet on hinges, but I don't like how it looks like. So I did a scoop
Chris
Post Posted: Wed Feb 25, 2009 12:34 am
Do you have the TBI or multipoint version of EFI?
I think the TBI is not quite as tall as the multipoint version, but there's probably not that much in it.
As Scrawn said I have the multipoint version fitted to mine with no bodylift. I made custom engine mounts which lowered the engine about 50mm. I also made a transmission mount that lowered it by the same amount. There is some info and pics in my members thread, post up if you have any questions.
Post Posted: Wed Feb 25, 2009 12:43 am
umm just want to say that by lowering the engine the gearbox will have to come down with it?
just do you guys think the best way to do it is. pic would be good
Post Posted: Wed Feb 25, 2009 2:18 am
No, it will put the whole lot on an angle. I wasn't sure if that would tilt the fan into the rad so I dropped the trans as well. It turns out that my fan ended up very close to the rad, so I think it was worth while.
Whatever works for you is the best way. Would I do it again? Yes, but next time around i'd try to incorporate some damping into the engine mounts. The almost solid setup I have get's a little tiring sometimes.
Pics are in my build thread.
Post Posted: Wed Feb 25, 2009 9:22 pm
yer i dont realy want the engine and gearbox on an angle. so i will probably try spacing the bonnet or give the bonnet the chop
Post Posted: Thu Feb 26, 2009 6:30 am
The EFI 1.6 will fit without a BL, but you need to modify the inlet pipe bracket so that it allows the inlet pipe to sit down closer to the rocker cover. And it is still TIGHT!!
Having said this, the carby and single piont EFI motors are just too tall.
Post Posted: Thu Feb 26, 2009 3:17 pm
Tight? How tight are we talking? And is it the inlet pipe that only needs dropping? Do you need to cut any ribs out of the bonnet?
Cheers Dan
Post Posted: Thu Feb 26, 2009 3:51 pm
Are you talking 16v or 8v Pete?
Post Posted: Thu Feb 26, 2009 10:04 pm
ok i had a rough look around and all the engine SHOULD clear if not it will come very close.
the airbox on the otherhand, no way it will fit. i might be able to lower the airbox a bit.
other problem is my winch wont fit on anymore and will need to chop into the body, any recomendations on this one?
and also modifly my tube bar.
Post Posted: Fri Feb 27, 2009 12:16 am
what winch?
Post Posted: Fri Feb 27, 2009 1:10 am
my mate that helped me put my 1.6 efi in my zuk has a 1.6 multi point in his maruti with no bodylift or any lift at all.i dont know if the one litre mounts originally help with this or not but it clears
Post Posted: Fri Feb 27, 2009 1:47 am
yer the engine is going to clear but the airbox wont. i am shure i will be able to move it down though.
ive just got a cheapy 6000lbs ebay winch.
Post Posted: Fri Feb 27, 2009 9:34 pm
ok its going to be going ahead.
just need to know the thread on the body studs and the bolt lengths? is anyone able to help me out here
Post Posted: Fri Mar 13, 2009 9:12 pm
ok i got the bolt and nuts and all the other gear. all i need to do now is make that engine fit under that bonnet. was thinking of making a bigger buldge in the bonnet
Vehicle: 75 Cruiser
Post Posted: Fri Mar 13, 2009 9:52 pm
nissvit put a 1.6efi in his Sierra with no body lift. He used a Calmini kit, which is basicly a modified drivers side engine mount.
Post Posted: Fri Mar 13, 2009 11:23 pm
Guess it's a weld on job. Engine will need to come out also???
Vehicle: 75 Cruiser
Post Posted: Fri Mar 13, 2009 11:40 pm
not a "weld on" job. You just need to make a engine mount that makes the sit in the right position.
Post Posted: Fri Mar 13, 2009 11:56 pm
so the calmini kit doesnt have the engine mount and i will need to make an engine mount?
Vehicle: 75 Cruiser
Post Posted: Sat Mar 14, 2009 12:01 am
now you're trying to confuse me.
The Calmini kit includes the engine mount.
I am just saying that if you can make your own engine mount you wont need the Calmini kit.
Post Posted: Sat Mar 14, 2009 12:16 am
Steve do you mean the conversion kit that has the gearbox adapter and drivers side mount similar to BenTs on O/L?
Post Posted: Sat Mar 14, 2009 12:24 am
yer im not sure how to make the engine mount
Vehicle: 75 Cruiser
Post Posted: Sat Mar 14, 2009 12:28 am
if you can make stuff you wont need this.
http://www.puresuzuki.com/1600cc_bolt-in.htm
Post Posted: Sat Mar 14, 2009 12:32 am
yer i am capable of making an engine mount but i dont know how to make it so it lowers the engine
Post Posted: Sun Mar 15, 2009 6:04 pm
steve where abouts did you mate buy the calmini kit from?
Vehicle: 75 Cruiser
Post Posted: Sun Mar 15, 2009 6:24 pm
I'm pretty sure it was new so probaby from Calmini.
If you can make an engine mount, you should be able to make one a little different so it lowers the engine. Sit the engine in the right place and make a mount to suit?
Post Posted: Sun Mar 15, 2009 9:43 pm
yer i guess that what i will need to do. but i am considering the calmini kit because of the engine/gearbox adaptor (gearbox on it way out)
if i do make my own mounts will need to make one for each side so the engine doesnt sit wonkey
Vehicle: '92 Sierra
Post Posted: Mon Mar 16, 2009 12:42 pm
Thats interesting. I've found the opposite. The carby and single point injected 8 valve donks (which I've got in mine with no body lift) fits with the stock 1.3 air intake pipe but the 16 valve wont fit without engine mount mods.
Users browsing this forum: No registered users and 326 guests
