It is currently Thu Jul 23, 2026 10:04 am
Post Posted: Thu Mar 12, 2009 4:37 am
I have my sierra fan. Now i forget which way to put it back on.
Does the air change direction if the fan is put on the wrong way?
Post Posted: Thu Mar 12, 2009 9:35 am
yes. I'm not 100% sure only 90%, but I think it's supposed to draw air through your radiator towards your engine.
Post Posted: Thu Mar 12, 2009 11:29 am
doesnt matter which way you put it on it will still pull air through, but you need the correct edge leading or it wont be as good
Post Posted: Thu Mar 12, 2009 12:54 pm
You will notice the fan blades have one straight edge and one curvy edge.
Put the straight edge to the front.
Jas.
Post Posted: Thu Mar 12, 2009 1:45 pm
Ok. My fan has 1 straight edge, and one like a broken brittle plastic edge :?
Vehicle: MY2019 Jimny
Post Posted: Thu Mar 12, 2009 2:01 pm
It will only swap suck for blow if you start running your engine backwards.
I know you installed it, so there is a distinct possibility that you may have funked something up to that extent...
Post Posted: Thu Mar 12, 2009 2:13 pm
HAHAHA no im not that bad, Just seeing if i put it on the right way at the very beginning of the engine conversion a long time ago! May help with cooling alittle.
Post Posted: Thu Mar 12, 2009 2:23 pm
FRONT.... Faces radiator.
BACK.... Faces engine.
Post Posted: Thu Mar 12, 2009 4:03 pm
Ok just looked. My fan is the same. It is on backwards.... 8O
Now with the new radiator that is goin in..its going to affect the clearance because of the offset! AAArgh!
Post Posted: Fri Mar 20, 2009 3:01 am
I call BS :finger:
YOU have it on the wrong way.
As you can see in the 1st pic. 4 Holes. With metal bushes. Look at the centre hole. It has a thin square plastic edging which supports the face of the alloy mounting block, then pokes through the hole. The other side does not!!
Post Posted: Fri Mar 20, 2009 3:39 am
you have it the same way as jas.
look again
Post Posted: Fri Mar 20, 2009 4:09 am
I did. Maybe you should look again. :lol:
All MY pics are from the back, the side that faces the engine. With the plastic support square,then alloy block, then bolts to the pulley.
Lip edge goes to radiator. Straight/internal gussets edge goes to engine.
Jas. Has Straight/internal gussets edge to radiator. Lip edge to engine.
I dont know how else to explain. every other way to explain it is confusing.
And im tired :?
Post Posted: Fri Mar 20, 2009 12:23 pm
Hi Bluesuzy, mate the side with the 12 little gussets faces the raditaor, I double checked with a lady at work who has a 1994 sierra, she has had it from new, 51000km, original water pump, fan has never been off the engine.
Post Posted: Fri Mar 20, 2009 12:44 pm
You can fit your fan whichever way you like.
I'll stand by the pics I posted.
Post Posted: Fri Mar 20, 2009 1:46 pm
Then why the square plastic support?
:thefinger:
Post Posted: Fri Mar 20, 2009 2:20 pm
:thefinger:
Who cares?
If the spacer was supposed to go the raised square bit you mention, the raised part would extend to the bolt holes.
If you put the raised bit to the spacer and then tighten the bolts you will bend and possibly damage the fan.
Jas.
Post Posted: Fri Mar 20, 2009 2:54 pm
Yep you're right jas......try it BlueSuzy you will see it actually sits on better as well.
Vehicle: '92 Sierra
Post Posted: Fri Mar 20, 2009 3:19 pm
For the big picture who here really thinks there would be a substantial change in airflow either way? Fix your shroud blue. :P
Post Posted: Fri Mar 20, 2009 4:07 pm
Just chuck it in reverse and it will blow the other way.
LMAO
Post Posted: Fri Mar 20, 2009 5:01 pm
New radiator is different. Shroud is fixed with a starlet thermo fan shroud. The motor is cutout of it. Will post pics later. Looks good atm.
Ok i will mount the fan you guy's way.
No matter how i think LOL
Users browsing this forum: Google [Bot], Pezooki and 60 guests
