It is currently Tue Oct 13, 2026 8:40 am
Post Posted: Wed Mar 21, 2012 12:24 pm
Have all other AC components from a WT. But they are useless without this.
Post Posted: Thu Mar 22, 2012 9:52 pm
Is there any way of fitting a/c to a coily with only wt bits?
Post Posted: Fri Mar 23, 2012 7:26 am
The under dash section (evaporator) is different between coily and WT.
If you are desperate to get it working get under your dash and take some measurements then go to a wreckers and look for something suitable out of a Lancer of Kia or Hyundai.. Doesn't matter as long as it fits. NipponDenso is a quality brand.
I did a RH conversion on a Mustang years ago and we ended up using a Sigma evap.
Post Posted: Sat Mar 24, 2012 9:25 am
would this be the part that I need?
http://www.ebay.com.au/itm/EVAPORATOR-S ... 061wt_1139
Or would I be able to source something with similar dimensions to make it all work?
Post Posted: Sat Mar 24, 2012 9:52 am
The description sounds right but the picture is definitely not a Sierra evaporator.
Post Posted: Sun Mar 25, 2012 7:11 pm
the brother in law is wrecking a coily. ill see if he has one for you
Users browsing this forum: No registered users and 59 guests
