It is currently Sun Nov 08, 2026 11:29 am
Post Posted: Tue Mar 27, 2012 4:41 pm
i need a compleate front pinion and wheel and diff centre for my 99 gv
wrecker here wants $900 and it needs bearings is there a cheaper option out there?
numbers is 8/39 i think its 4.875?
where and who can i get it from overseas is a option
Post Posted: Wed Mar 28, 2012 2:24 am
Hawk Simply Suzuki had GV parts but they went out of business - their stuff went to Low Range Off Road and Trail Tough -
Post Posted: Wed Mar 28, 2012 3:17 am
hey mate, im pretty sure i have one. ill double check the ratio in the morning. where in perth are you?
Vehicle: 4wd
Post Posted: Wed Mar 28, 2012 7:34 am
You might get a few more views if you post this in the wanted section.
Watch out or you'll get sued.
Post Posted: Wed Mar 28, 2012 8:09 am
4.8 from a vitara or a X90 will fit and dont have the stupid air operation setup. Much easier to fit but you have to run manual hubs....
Ill have a look at what i got at home tonight but post may be a killer.
Post Posted: Wed Mar 28, 2012 11:34 am
sorry mate, i have 4.3 diff, if you need that pm me.
Vehicle: 2001 XL7
Post Posted: Wed Mar 28, 2012 1:18 pm
suzifour in sydney, worth a call
Post Posted: Wed Mar 28, 2012 1:58 pm
I've got one, but I can't remember if it's a front or a rear. I'd have to count the teeth.
If your not breaking shit, try harder!!!
Post Posted: Wed Mar 28, 2012 5:09 pm
thanks for all the help have got one now
was $550 but its all cast iron now shouldnt break this one
Post Posted: Wed Mar 28, 2012 5:13 pm
What model was it from? just to confirm correct ratios.
Post Posted: Wed Mar 28, 2012 5:36 pm
was from a gv not sure what year but the teeth count was right
only needed the pinion wheeel crown and housing so if anyone needs the diff let me know
Post Posted: Wed Mar 28, 2012 5:41 pm
why not just bolt it in complete rather that paying someone to strip the crownwheel & pinion out of it & build up another one?
you said the replacement one was steel & i'm guessing your old one was alloy... doesn't not make sense to be swapping R&P's.
Post Posted: Wed Mar 28, 2012 5:44 pm
im not getting all this work done and skimp on some bearings in the diff
would distroy me finacially
Post Posted: Wed Mar 28, 2012 5:50 pm
ahhh, cool. how many kms were on the replacement diff?
Post Posted: Wed Mar 28, 2012 5:52 pm
no idea was out of a wreck with no in sides
will post up some pics of the distroyed one next week
Post Posted: Thu Mar 29, 2012 4:20 pm
If ya only use the ring and pinion i want First dibs on the steel housing and 3rd carrier......
You have PM
Post Posted: Thu Mar 29, 2012 6:35 pm
sorry but im using that:) only have the diff the inside bit
now have run into another problem ahhhh
the bracket for the nose part of the diff is different to the ali one and the guy i got the steel housing off cant find the bracket ?
any one have one lying around?
Post Posted: Thu Mar 29, 2012 6:43 pm
pics of what you have so we know its not that.
Post Posted: Thu Mar 29, 2012 6:44 pm
its at the diff shop will have to get some pics of it tomorrow
Post Posted: Thu Mar 29, 2012 6:48 pm
which one out of these 2 is the one you're after?
the furthest away one is also the same as the normal Vitara ones.
Post Posted: Thu Mar 29, 2012 6:53 pm
i assume its the closest one it only fits steel diff
i havent seen mine yet ive been dealing with diff shop on the phone
suzistore said they know what im after but dont have one
Post Posted: Thu Mar 29, 2012 6:55 pm
don't assume anything, steel diffs come in both styles of mounts.
what year is your GV?
Post Posted: Thu Mar 29, 2012 7:00 pm
99 but not sure of the year the car came out of
Post Posted: Thu Mar 29, 2012 7:06 pm
99 will most likely be the early style of mount & if that's the case and that your pinion mount doesn't fit you're after the later style... but i'd double check first.
Post Posted: Thu Mar 29, 2012 7:07 pm
ok so if it is do you have one forsale?
Post Posted: Thu Mar 29, 2012 7:11 pm
sorry, i've only got earlier style of mount :(
Post Posted: Thu Mar 29, 2012 7:26 pm
so the picture closest is the new style and the top square one is the old style?
Post Posted: Thu Mar 29, 2012 7:31 pm
yep that's it
the change over was around 99 which makes it hard, the early one is also the same as any Vitara.
Post Posted: Fri Mar 30, 2012 11:01 am
just got back from diff shop
its the closest one in the pic above
Post Posted: Fri Mar 30, 2012 1:38 pm
can get a genuine one from suzuki
$140 ex japan 4 weeks deliveriy time ahhhhhhhhhhhhhhhhhhh
Users browsing this forum: Google [Bot] and 73 guests
