It is currently Thu Aug 06, 2026 10:14 pm
Vehicle: Suzuki Grand Vitara
Post Posted: Sat Mar 31, 2012 4:21 pm
The last couple of days the water temp gauge needle in my Vitara has been jumping up and down from half to nothing.
Anyone had this happen?
Would this be a faulty instrument or the temp gauge on the manifold?
Post Posted: Sat Mar 31, 2012 4:37 pm
I'll wager the spade terminal on the sender is loose on its rivet, tap it tight with a chisel (lightly) and it should come good
Loose earths or wires could do that.
Not just sender, but motor earths, cluster earths etc.
Post Posted: Sun Apr 01, 2012 2:16 am
i had this issue with my last sensor, replaced it and it came good. then last nite driving down the freeway my gauge starts having a fit and i thought i must of been getting air pockets or loosing coolant etc. pulled over not a drop anywhere, had a look at the terminal to see only a 2 wire connection on the terminal 8O , clamped it to get home. put a new one on to day = good as gold.
Post Posted: Sun Apr 01, 2012 7:31 am
Thanks for the reply will try a few.
Vehicle: 94 Vitara LWB G16b
Post Posted: Sun Apr 01, 2012 2:17 pm
I had this issue - was a short from where an engine mount rubbed on the wiring harness. It also caused other issues.
viewtopic.php?f=5&t=18001
94 Vitara LWB G16b
Users browsing this forum: Google [Bot] and 367 guests
