It is currently Sun Nov 08, 2026 3:05 am
Post Posted: Mon Apr 02, 2012 9:50 pm
My Swift just threw a CEL on the drive home tonight - before I take it into the dealership, does anyone here know how to get the codes without the special diagnostic tool?
I want to know if its ok to keep driving it or not...
Also, whatever is causing the light, should be covered under warranty, right?
I want my old sig back :(
Post Posted: Mon Apr 02, 2012 9:55 pm
CAT usually does this. Its probably run its coarse and due for replacement. But the only REAL way to know is to chuck the scan tool on. If its the cat, o2 sensor etc it will probably be listed as a servicable part, and not covered by warranty.
The Cat is welded into the headers, and part of the header assembly, so if it DOES turn out to be this, get a price on having the cat insert changed by an exhaust shop before you let suzuki talk you into a new manifold.
Post Posted: Mon Apr 02, 2012 9:58 pm
Is it a generic scan tool or a Suzuki specific one? I.e. can my mate up the road do it, or does it need to go to a dealership to get the code?
Surely after 2.5 years and under 40,000km the cat or o2 sensors shouldn't be failing...?
Post Posted: Mon Apr 02, 2012 10:08 pm
Cats are only warranted for 2years. Most manufacturers only give 12 months. Quality of fuel, usage and environment can all alter the life of a cat converter. Same with O2 sensor.
Last I checked you can use a generic scan tool, but it needs the suzuki software. And still, it may not show everything.
Post Posted: Mon Apr 02, 2012 10:24 pm
This why stekky was handy to have around :wink:
Post Posted: Tue Apr 03, 2012 7:42 am
I had this on my subaru, lucky i knew someone enough to claim it for warranty(aftermarket warranty)
@$300 a sensor, x2, i wasnt happy..soo lucky
Post Posted: Tue Apr 03, 2012 9:35 pm
Any generic scan tool can read late model suzuki's they run generic codes.
Most common for swift sport check lights coming on is a code in EGR system, have replaced a couple of them followed by O2 sensors then Cat converters so don't just jump to any conclusion, get it checked properly.
Suzuki is my way of life.
Post Posted: Tue Apr 03, 2012 11:10 pm
Its in at Melville Suzuki on Thursday, so I'll wait and see...
Post Posted: Fri Apr 06, 2012 12:09 am
So, apparently:
"Found code p0420 in history and fault not present at time of tests, cleared code and road tested fault did not return"
Something to do with emissions, apparently, but nothing wrong with any component, and it went away by itself... The guy reckoned it may have been a bit of bad/stale fuel or something... We shall see...
Post Posted: Fri Apr 06, 2012 12:25 am
:hey: Sean
Post Posted: Fri Apr 06, 2012 6:36 pm
And back on again. :evil:
Post Posted: Fri Apr 06, 2012 6:43 pm
The code should indicate which part of the EGR system is in error. Good to see he tested the offending sensor before sending you on your way :roll:
Post Posted: Fri Apr 06, 2012 7:21 pm
He said it was a "miscellaneous" code...
Post Posted: Fri Apr 06, 2012 8:40 pm
Not sure if thats true or not, but i'd wager the super genuis' at suzuki didn't put a code in the ECU named 'miscellanoeus' :roll:
Post Posted: Fri Apr 06, 2012 8:58 pm
It will be going to Premier Motors this time... They're a bit further away but at least I know I'll get looked after properly...
Post Posted: Sat Apr 07, 2012 1:06 pm
have you googled "suzuki swift sport code p0420"
cos i just did and got a TON of results... this one gave a good list: http://www.fixya.com/cars/t4467384-engine_code_p0420
Users browsing this forum: Google [Bot] and 87 guests
