It is currently Mon Nov 09, 2026 3:47 am
Vehicle: ***
Post Posted: Thu Apr 05, 2012 3:46 pm
Currently running procomp rims 15x8 with 31x10.5 bighorns. Not sure of offset I can see 22 written on them but not sure if it's an indication of the offset ;/
they are mere millimetres from the leafs.
I've got some CSA magnums 15x7 I want to put on and their offset it N6. Which to me looks like the Inner part of the rim sticks out further from the studholes. 115 mmls where the Others are 105ish
I'm thinking if the procomps are close to hitting the leafs the Magnums definatly will or am i missing something completely.
Do I need to buy Spacers or will they fit?
Thanks
tyron
Post Posted: Thu Apr 05, 2012 3:58 pm
measure from the wheel mounting surface of each type of rim to the inner edge of the rim and see what the difference in offset is.
without knowing what offset the rims your talking about are its not going to be easy to advise you. procomps come in alot of different types and offsets
Vehicle: ***
Post Posted: Thu Apr 05, 2012 4:03 pm
yeah that was the inner, i measured. 115 for the magnums and 105 for the procomps.
Vehicle: ***
Post Posted: Thu Apr 05, 2012 4:04 pm
I was hoping someone has 15x7 N6 to reply and just say wether they fit or not.....
Post Posted: Thu Apr 05, 2012 4:16 pm
I doubt 10mm will make enough difference to matter
Vehicle: ***
Post Posted: Thu Apr 05, 2012 4:20 pm
it's less then 10mm away from the leaves :|
Post Posted: Thu Apr 05, 2012 4:22 pm
Mine rub on the leaves. The worst part about it is a polished spot on the leaf.. nothing bad happens.
Post Posted: Thu Apr 05, 2012 4:27 pm
a little scrubbing isnt going to hurt on the springs. better than running highly illegal wheels spacers
Vehicle: ***
Post Posted: Thu Apr 05, 2012 4:37 pm
I'm not worried about the springs,
I'm worried about how much of tyre im going to loose.
that It may not be worth changing the rim.
<a href="http://s130.photobucket.com/albums/p261/Bazil_tye/?action=view&amp;current=IMG-20120405-00137.jpg" target="_blank"><img src="http://i130.photobucket.com/albums/p261/Bazil_tye/IMG-20120405-00137.jpg" border="0" alt="Photobucket"></a>
Vehicle: ***
Post Posted: Thu Apr 05, 2012 4:38 pm
Post Posted: Thu Apr 05, 2012 4:42 pm
Mine have rubbed on the leaf for over 12months.. They're all good.
As i said the WORST part is the lack of paint on the leaf. Your tyres will be fine. You have 1mm less offset than me if -22 is your offset.
It will be fine.
Post Posted: Thu Apr 05, 2012 4:43 pm
if that is full lock there is a good 15-20mm of space there.
your not gonna loose enough of your tyre to even notice.
Post Posted: Thu Apr 05, 2012 9:19 pm
It will be fine.
The worst part is if it locks up on the leaf enough under power to snap your CV, not really a problem without big outer lug tyres like swampers or pedes though.
Post Posted: Fri Apr 06, 2012 9:54 am
Rubbing and locking up are very different though.
Post Posted: Fri Apr 06, 2012 10:23 am
Mine used to rub on -28's.
Cleaned the springs..
It is a technical rego thing. No part of tyre shall come in contact with anything else.
Post Posted: Sun Apr 08, 2012 7:55 pm
what about the inside of the tyre and the rim? :)
Users browsing this forum: No registered users and 106 guests
