It is currently Sun Nov 08, 2026 3:01 am
Post Posted: Fri Apr 06, 2012 7:24 am
Hi guys need some help,
Changing the timing belt on my g16b and all i have to go by is gregwatkins75 g16a how to...
viewtopic.php?f=17&t=26098&hilit=timing+belt
I have removed the timing belt cover and noticed that on the top pulley there is two notches, One for E and one for I, which one do i line up with the notch on the engine casing?
Im presuming i rotatae it two full turns clockwise and line up the E?
cheers guys!
Post Posted: Fri Apr 06, 2012 7:46 am
if your just changing the belt
all you need to do if you cant figure the marks out is find a straight edge and mark the pulleys straight though the center of crank all the way to center of cam .
mark top and bottom of pulleys so you know they are in exactly the right spots.
I did mine a while back and from memory I had some dots on the pulleys that all lined up when it was correct, but that was 18mths or so ago.
as long as every thing stays lined up you relly cant fuck it up
Post Posted: Fri Apr 06, 2012 8:29 am
had the same prob a couple weeks ago its the E
hope this helps
viewtopic.php?f=5&t=31304&hilit=1.6+wont+start
Post Posted: Fri Apr 06, 2012 8:32 am
The cam gear should have the dowel in the E hole.
You line up the E mark on the rim.
Post Posted: Fri Apr 06, 2012 9:29 am
no worries fellas, took a punt and got it all sorted, is there any torque specs for the waterpump bolts and tensioner bolt? cant seem to find any??
thanks, mark.
Post Posted: Fri Apr 06, 2012 11:02 am
Haynes says 17.5-21.5 ft-lb for the tensioning bolt, 7-8.5 for the adjuster nut.
Water pump bolts are 7-9 ft-lb.
Post Posted: Fri Apr 06, 2012 12:25 pm
cheers DarkHorse.
all done and running well:)
Users browsing this forum: Google [Bot] and 121 guests
