It is currently Sun Nov 08, 2026 3:06 am
Post Posted: Thu Apr 05, 2012 10:53 pm
Hey guys and girls I've got a 89 wt Sierra and I have a rattling sound coming from the the front right side I'm not to sure if its bearings there only a couple of months old except the king pin bearings and they stuffed up a couple weeks ago so they'll be getting or should I look at the spigot bearing? Thrust bearing even or a rooted clutch?? I hope I can find some help all these noises are shitting me up the wall :rambo: hahaha hope someone can shed some light on this thanks for reading and the help
Post Posted: Thu Apr 05, 2012 11:51 pm
if its the front right, I'd jack the whole front end up and check the wheel bearings. Wiggle the tyre from the top and bottom/push pull. You will then see if it is the kingpins again or wheel bearings. Both sides.
What size tyres/rim offset do you run?
Post Posted: Fri Apr 06, 2012 9:36 am
I have play from top to bottom I'm running 30s and not to shore about offset thanks for that I'm pull it apart and see what I can find
Post Posted: Fri Apr 06, 2012 9:52 am
Ive had a kingpin collapse so the play was in the whole hub/knuckle assembly
Also loose wheel bearings was the norm for mine.
You definatly have something going on. There should be no play.
Post Posted: Fri Apr 06, 2012 10:15 am
Yer it's not to bad just noisy lol nah I reckon my kingpins are shagged and stuffing up my wheel bearings or maybe something else I just ordered a swivel hub rebuild kit off egay hopefully get it next week and do it then cheers for the help buddy Apprectiate it alot
Post Posted: Sat Apr 07, 2012 1:04 pm
I think a part of my problem is my unis from the gearbox to tcase aswell there's little movement like 2 mm each way are all the unis the same?? Noob question I know but I'm just making sure thanks fr the help
Post Posted: Sat Apr 07, 2012 2:40 pm
you mean turning, 2mm backlash, or in the joint itself.
backlash is normal.
play in the joints are not.
Post Posted: Sat Apr 07, 2012 3:02 pm
Play in the joints where the caps are backlash I'm not to fussed about lol
Post Posted: Sat Apr 07, 2012 5:20 pm
play in the joints is no good. replace asap.
Users browsing this forum: Google [Bot] and 97 guests
