It is currently Sun Nov 08, 2026 3:00 am
Post Posted: Mon Apr 09, 2012 11:33 am
Ok gurus, I was sure that the 1.3l and 1.6l heads were the same, except internally, but I cannot hookup the exhaust, seems from the front aft, the front lines up, but the back is about half a bolt hole out.
Am i doing something incredibly stupid here, or do I need vitara extractors.
Post Posted: Mon Apr 09, 2012 12:24 pm
1.6 ex ports are bigger than 1.3, bolt pattern is the same...
however my 1.3 tuned length extractors port size was big enuf to suit the 1.6
and bolted straite on..
maybeyour extractors are hiting somewhere? puting the bolt hole allignment out of wack.
Post Posted: Mon Apr 09, 2012 12:28 pm
The ports are a bit bigger, yes, but measured the extractors and they are bigger by a bees dick, so alls well.
There is nothing hitting as I can see, plenty room, tried the inlet, perfect fit.
Hmmm, out to try again.
Post Posted: Mon Apr 09, 2012 12:46 pm
Use the 1.6 manifold and bolt the 1.3 exhaust to it that works did it to mine
Post Posted: Mon Apr 09, 2012 2:25 pm
Didn't come with a manifold, bugger, you are right, bees dick diff, well, too much more than that, or itd be just a file out.
Users browsing this forum: Google [Bot] and 138 guests
