It is currently Mon Nov 09, 2026 6:05 am
Post new topic Reply to topic  [ 36 posts ]  Go to page Previous  1, 2
Vehicle: LWB Sierra & XL7
Post Posted: Sat Nov 12, 2011 11:42 pm
I went past but obviously you fixed it cause you wern't home. :p
'92 Vitara & Camper trailer
Post Posted: Sun Nov 13, 2011 12:31 am
Push a screwdriver between the curved serated parts of the hand brake adjuster and push in. This will make the adjuster piece go all the way in to zero adjustment. Hold it in when you pull the screwdriver out, and the zero adjustment will stay. then put drum back on. It may also be a help to make sure the hand brake adjustment is slackened well off at the lever end. Adjust this back up when drum/drums are back on. Once things have bedded in, you will need to readjust at lever end.
Hope this helps,
Pete
Post Posted: Sun Nov 13, 2011 2:22 am
yeah buzbox! Just got to bleed the breaks still, drove to work down the road haha, got called into work last minute... haha
Post Posted: Sun Nov 13, 2011 5:04 am
8O you drove it with out bleeding the brakes didnt you put new wheel cly's in it? 8O
 Profile YIM
Post Posted: Sun Nov 13, 2011 5:14 am
With new wheel bearings in he could push the car and still get to work, no need for brakes, except to park :lol:
lucky bugger.
Post Posted: Tue Apr 17, 2012 5:42 pm
thanx bro i am in the middle of doin all my bearings and break shoes im glad this thread was up because i had a same trouble getting the rear drums on but reading this cleared it right up
Users browsing this forum: No registered users and 52 guests
