It is currently Thu Jul 23, 2026 8:22 am
Post Posted: Tue Mar 31, 2009 11:38 pm
hi just wanting to know what other starter motors fit the zuk as my one has died and dont want to buy an new one ( well dont have the money atm) but an mate has an few old padock bashers that i can take one off if it will fit
Post Posted: Tue Mar 31, 2009 11:48 pm
Any starter from a Suzuki Sierra G13 should fit Image
Post Posted: Wed Apr 01, 2009 12:00 am
i dont have an nother sierra or i would of taken it
there was an swift but it looks to have an difrent mounting plate to it ( it was an carby g13) but i was hoping somthink like an old carolla or somthink might fit
Post Posted: Wed Apr 01, 2009 2:48 am
Have another look at the swift one. As far as I know only Sierra ones fit. Maybe Swift if it is a G13 block?
Post Posted: Wed Apr 01, 2009 12:19 pm
Mine died not long ago, got it reconditioned and fitted for $200. Had a go myself [visually] but decided to get someone with small hands to do it for me. They even sprayed it silver!
Post Posted: Wed Apr 01, 2009 3:24 pm
i have a gti one on mine
Post Posted: Thu Apr 02, 2009 9:41 pm
so 200 was with them removing it from the car ( that is the easy part) as i might jut get my one reconed if it isent going to cost much
Post Posted: Thu Apr 02, 2009 9:45 pm
I believe swift is different, I am sure somebody here once said Lancer ones fit?
lesspostingmorewheeling
Post Posted: Fri Apr 03, 2009 1:48 am
i think bluesuzy said something about a lancer one
Post Posted: Fri Apr 03, 2009 10:18 am
i did try the one from an fwd swift ( but it had an improt motor on it ,still an g13b) but it was difrent ,but think now i remember theat an exel one might be the same
Vehicle: LJ20 LJ50
Post Posted: Fri Apr 03, 2009 3:41 pm
It would only be the front housing that would be different, so by swapping the guts over it should be the same.
Camels have nice toes
Post Posted: Fri Apr 03, 2009 3:58 pm
No swift wont fit
Have alook at the older lancer, Thinking 1st coupes and the boxy hatch type before that. Carbie model
Sierra starters are mitsubishi brand, So i went straight to the source :D
Swift starters are denso or something.
I used the internals to fix my starter, But they looked the same. I snapped the slip drive gear doova thingomobob
Best bet would be go to a wreckers with your starter, and see what they have got, or pull some out.
Whats wrong with it anyway?
There's only like 5 parts in a whole starter. Can't go wrong if your alittle mech minded.
Clean all, grease up swing arm doova and spline, Wack it back together, she'll be right. Unless the electric motor is worn/gone..
That makes me think, My starter makes a weird wirrr noise after its starter the motor :? The mystery of suzy again :lol:
Post Posted: Fri Apr 03, 2009 11:58 pm
the solanoid is ruted and not throwing the gear out in to the flywheel ( it some times worked on the bench ) but the whole thing iw heverly worn
Post Posted: Sat Apr 04, 2009 5:27 am
Ok definately find parts only. If the wreckers will let u have the solinoid only.. Its a simple job
Try cleaning it out 1st!
Stand on the housing and make it activate/work with some jumper leads and extra wire for the ignition switching, should be ok..
Before you put it back in the car!! Just in case.
Post Posted: Sun Apr 05, 2009 12:12 am
already done all that ( it is fucked )
Users browsing this forum: Google [Bot] and 60 guests
