| Author |
Message |
just_cruizin
Joined: Sun Jun 25, 2006 11:30 pm Posts: 2867 Location: here
 Posted: Thu May 03, 2012 11:59 am |
Apart from the atlas the LT230 is the choose transfer in mid weight vehicles.
I'm guessing if the 2.0 is staying it'll be force feed in the future.
_________________ greenzook89 wrote: 31zook wrote: Makes me want something similar
Fatzook
 Posted: Thu May 03, 2012 12:23 pm |
just_cruizin wrote: I'm guessing if the 2.0 is staying it'll be force feed in the future.
I'm not ruling that out. It may not be necessary anyway, but I'd like to know that I have a driveline thats up to the task atleast.
SierraDan
Joined: Fri Feb 04, 2011 10:55 pm Posts: 9348 Location: Newcastle
 Posted: Thu May 03, 2012 12:32 pm |
My mates buggy has The LT230 behind a 3.8 on 37's, cops a flogging without issue.
_________________ mlm
JrZook
 Posted: Thu May 03, 2012 12:35 pm |
zooky08 wrote: Last time I was at double island. A landy smashed some thing in his transfercase right in front of us trying to do this sand dune. He had no drive to his rear wheel. Not sure how strong they are but some thing broke quite easy. These transfers do die if the center-diff lock is not in and you attempt large climbs. Front end unloads, center diff spins like crazy and gets starved of oil due to the angle and then bang!
_________________ Lil Foot!
tanshi
 Posted: Thu May 03, 2012 2:15 pm |
Dont tell me that the case isnt going to be strong enough pete!!!! these are not the details i want to hear this far into my build!
JrZook
 Posted: Thu May 03, 2012 2:16 pm |
You will be right. Just add a roll of duct tape around the tcase for extra reinforcement and call it done
tanshi
 Posted: Thu May 03, 2012 2:20 pm |
i'll just worry about it when it goes bang.
Fatzook
 Posted: Thu May 03, 2012 2:23 pm |
tanshi wrote: i'll just worry about it when it goes bang. hmmmm.
Highway-Star
Joined: Thu Apr 30, 2009 11:30 pm Posts: 4109 Location: Ipswich
 Posted: Thu May 03, 2012 2:28 pm |
3cyl has a big fat 1990's Defender factory service manual with service info on the LT230 transfer in it (I was flicking through it the other day at his place). That book might have some info you are after in it? Not sure if he has his computer back yet, but I could go bug him this weekend if you want Pete?
_________________ Clearance Hole Technology
tanshi
 Posted: Thu May 03, 2012 2:35 pm |
Fatzook wrote: tanshi wrote: i'll just worry about it when it goes bang. hmmmm. I'm thinking it goes bang after the rear diff any ways
Fatzook
 Posted: Thu May 03, 2012 3:09 pm |
Maybe not. Either way, now is the time to remove your glass parts..... not once the build is done.
zooky08
Joined: Fri Nov 27, 2009 10:30 pm Posts: 3426 Location: imbil/gympie. qld
 Posted: Thu May 03, 2012 3:51 pm |
JrZook wrote: zooky08 wrote: Last time I was at double island. A landy smashed some thing in his transfercase right in front of us trying to do this sand dune. He had no drive to his rear wheel. Not sure how strong they are but some thing broke quite easy. These transfers do die if the center-diff lock is not in and you attempt large climbs. Front end unloads, center diff spins like crazy and gets starved of oil due to the angle and then bang! Okay then, well there was nothing to the dune. Was just a sand bank in front of our camp site. Was siting there on our deck chairs having a few beers and u see this landy come driving in and hit this bank. Transfercase went bang. Couldnt tell the guy, got in his car and went for it again. First thing we thought was, that's going to be expensive
_________________ 03 Jimny 30 km2s 75mm lift f&r locked winch
ZookFan
Joined: Mon Feb 14, 2011 6:19 am Posts: 3978 Location: Brisbane,samford,QLD
 Posted: Thu May 03, 2012 4:33 pm |
Fatzook wrote: che_guitarra wrote: AULRO is the best landie forum by a mile. You might be able to search their database without having to join Yeah I stumbled accross that site in my googling spree. its a HUGE site!  It's been running for a while mate
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13007 Location: Melbourne
 Posted: Thu May 03, 2012 5:47 pm |
Fatzook
 Posted: Thu May 03, 2012 5:51 pm |
Gwagensteve wrote: http://www.expeditionlandrover.info/gear_ratio.htm
1.41 ratio was in V8 and 300Tdi 110's - should be easy to find then.
Note there is a 1.667 ratio too, from 4 cylinder petrol 90's and 110's, but they were never sold here.
Steve. Yep. I can get the 1.667 out of the UK, but I really don't need the gearing. 1.4 is the same as the 1L case I have in there now. Thanks for the link.
sogone
Joined: Mon Oct 25, 2010 11:29 am Posts: 2070 Location: Darwin
 Posted: Fri May 04, 2012 9:10 am |
What diff gears are you running Poiter?
Fatzook
 Posted: Fri May 04, 2012 9:26 am |
4.6 12 bolt vitara rears, front and back. Having the side gears re-splined bigger for meatier float axles.
sogone
 Posted: Fri May 04, 2012 11:27 am |
And what size tire are you going to be running? If your only going to run 4.6s diff and a 1 liter (or equivalent) case would you not be limited to tire size (say a 30)?
got_bar_work
Joined: Sat May 15, 2010 8:30 pm Posts: 2214 Location: Brisbane
 Posted: Fri May 04, 2012 11:36 am |
JrZook
 Posted: Fri May 04, 2012 11:47 am |
SierraDan
 Posted: Fri May 04, 2012 11:53 am |
Not with 4.6 diffs. Would be pretty good with the 2.0L also. 3.7's and 1L transfer with 31's was JUST bearable. 3.9's made it pretty good. 4.6's and 33's with more power would be fine.
Fatzook
 Posted: Fri May 04, 2012 12:31 pm |
Here is how I look at it.
I am running Vitara motor, gearbox, diffs. The only thing missing is the transfer.
The 2L runs a 27" tyre standard ( I think). It has 4.6 diffs, manual gearbox (3.6ish:1), 1:1 transfer.
So that gives a ratio of 16.56:1 in high first, 4.6:1 in 4th or 3.68:1 in 5th..... on 27's.
With the 1.4:1 LT230, I will have the following.....
4.6:1 diff, manual gearbox, 1.4:1 transfer.
So that makes 23.18:1 1st, 6.44:1 4th and 5.152:1 in 5th. SO by my calculations that 29% lower than standard vitara gearing.
GIven that a 33% tyre is 6" taller my calcs put it at roughly 18% larger, changing the speedo reading by about 22%.
So after all this crap..... on 33's, I will have MORE High range gearing than a standard 2L vitara.
Fatzook
 Posted: Fri May 04, 2012 12:35 pm |
And with the above gearing, I get a 5th gear rpm of 3300@100. On 33's.
sogone
 Posted: Fri May 04, 2012 1:50 pm |
got_bar_work
 Posted: Fri May 04, 2012 3:01 pm |
Then u can go 5:12 and 35 later if u ever want
remydog05
Joined: Sun Nov 23, 2008 10:30 pm Posts: 1260 Location: Vic
 Posted: Fri May 04, 2012 5:55 pm |
See if you can track down slunnie from outers, he was up to speed on lots of options
Also I think Sam kneck used the same TC in a few buggies??
Letterbox
Joined: Sun Nov 27, 2011 1:14 am Posts: 17 Location: Inner Melbourne
 Posted: Fri May 04, 2012 7:11 pm |
One guy i will recommend who knows his stuff.
FRED SMITH AUTOMOTIVE PTY LTD 30 Havelock Rd Bayswater 3153 (03) 9720 4999
He is the most informative fella i have met. Knows crap most would never consider.
Been a Landy mechanic since the Army. In his Mid 50's and Fussy as. Has 2nd hand parts and New. competitive on price and good rates. Loves a Chat also...
Works on series to New and also works on most things British. Ohh must be a top bloke... Drives a Turbo Volvo.....
_________________ SierraWTSPOA2"BL5.1Diff4.16TCChromeCV33"
twitchy
Joined: Fri Jul 25, 2008 11:30 pm Posts: 1086 Location: Lightning Ridge
Vehicle: 1999 Jimny
 Posted: Sat May 05, 2012 1:25 pm |
Yo Zook, I have a mate around the corner who is a land rover nut & mechanic so I will find what you need to know. you do realise that it weighs about the same as your Zook??? They are F*$king heavy I've changed a couple & man... wow. Having said that if you get one make sure it has a TOTAL seal kit put in it & it should be ok..... just threw away a complete handbrake set up off one as well you could of had... sorry. Defender & Disco gearing is different for sure.
All stock LT 230"s have a low ratio of 3.321, the following list refers to the high range ratio.
12D = 1.667 LT 230R
13D = 1.410 LT 230R
14D = 1.003 LT 230R
15D = 1.192 LT 230R
20D = 1.667 (2.5 N/A 110),
22D = 1.410 (all 4Cyl 90/110 bar above),
25D = 1.410 (V8 110 LT 85),
26D = 1.003 (RR Classic 3 speed auto),
27D = 1.192 (early RR Classic),
28D = 1.222 (RR and Disco I),
29D = 1.192 (V8 90 LT 85),
32D = 1.222
34D = 1.410 (2.0 Disco I),
36D = 1.211
38D = 1.211
40D = 1.211 (NAS/Japan 90&Disco),
41D = 1.211 (Disco II, diff lock stud),
42D = 1.211 (Disco II, diff lock stud),
43D = 1.410 (90/110 TD5),
57D = 1.410 (90/110 TD5),
61D = 1.211,
62D = 1.211,
68D = 1.211,
69D = 1.211,
70D = 1.211 (Disco II, no diff lock),
SierraDan
 Posted: Sat May 05, 2012 4:23 pm |
All Four x Four Spares Newcastle could help should you need it.
Ask for Leigh: 0249571117
twitchy
Vehicle: 1999 Jimny
 Posted: Sat May 05, 2012 8:52 pm |
