| Author |
Message |
Rookie_zookie
Joined: Sun Feb 17, 2008 10:30 pm Posts: 266 Location: brisbane
 Posted: Sat May 19, 2012 1:47 pm |
Hi I'm just wondering can I full front end fit off a 96 coiley fix on a 94 model
_________________ Thanks Rookie_zookie :O)
zooky08
Joined: Fri Nov 27, 2009 10:30 pm Posts: 3426 Location: imbil/gympie. qld
 Posted: Sat May 19, 2012 1:59 pm |
front end what, diff or front clip?
_________________ 03 Jimny 30 km2s 75mm lift f&r locked winch
Rookie_zookie
 Posted: Sat May 19, 2012 2:15 pm |
Sorry front clip
sideways
Joined: Fri Oct 29, 2010 1:53 pm Posts: 5935 Location: Northcliffe, W.A.
 Posted: Sat May 19, 2012 2:34 pm |
Rookie_zookie wrote: Sorry front clip I believe you can, but it looks silly because the cowl is a different shape on a coily.
Rookie_zookie
 Posted: Sat May 19, 2012 2:39 pm |
It should just look like a coily won't it
boostedbrick
Joined: Tue Jun 29, 2010 7:44 am Posts: 2003 Location: Brisbane
Vehicle: 2018 DMAX
 Posted: Sat May 19, 2012 3:03 pm |
A coily bonnet on a WT will sit higher and look wierd. A wt bonnet on a coily front clip has square edges and looks weird.. Check about halfway down this thread viewtopic.php?f=4&t=32591&start=30
Rookie_zookie
 Posted: Sat May 19, 2012 3:46 pm |
It was every thing guards bonnet front grill it's wasn't just the bonnet
boostedbrick
Vehicle: 2018 DMAX
 Posted: Sat May 19, 2012 3:53 pm |
If you fit the entire coily front end, the bonnet will not fit. If you try to use the coily bits with a WT bonnet, the bonnet is the wrong shape.
One of the bonnets will need modifying to suit from the info ive seen..
Rookie_zookie
 Posted: Sat May 19, 2012 4:10 pm |
i think u might not get me sorry the front end comes with 2 side guards the front part and grill and the bonnet
fully sick coily
Joined: Tue Feb 14, 2012 7:47 pm Posts: 474 Location: brisbane
Vehicle: chick magnet coily
 Posted: Sat May 19, 2012 4:24 pm |
i recon it will fit
_________________ when in doubt... HOLD IT PINNED!!! :)
Red89
Joined: Tue Jan 12, 2010 10:30 pm Posts: 2801 Location: Perth
 Posted: Sat May 19, 2012 5:02 pm |
fully sick coily wrote: i recon it will fit  Youre an idiot. Rookie_zookie wrote: i think u might not get me sorry the front end comes with 2 side guards the front part and grill and the bonnet Did you look at the link boosted brick posted ? If you put all those parts on that you just listed the bonnet wont sit level where it meets the part at the bottom of the windscreen.
_________________ Made in JP. Built in WA.
Rookie_zookie
 Posted: Sat May 19, 2012 5:10 pm |
Red89 wrote: fully sick coily wrote: i recon it will fit  Youre an idiot. Rookie_zookie wrote: i think u might not get me sorry the front end comes with 2 side guards the front part and grill and the bonnet Did you look at the link boosted brick posted ? If you put all those parts on that you just listed the bonnet wont sit level where it meets the part at the bottom of the windscreen.  ok calm down i was on my phone when i asked this my phone did not let me load the link if i dont ask questions i wont learn
Bruce
Joined: Sun Jun 11, 2006 11:30 pm Posts: 4003 Location: Brisbane
 Posted: Sat May 19, 2012 5:13 pm |
Red89 wrote: fully sick coily wrote: i recon it will fit  Youre an idiot. x2
_________________ [quote="royce"] I wouldnt mind insulating my rear
Red89
 Posted: Sat May 19, 2012 5:29 pm |
Rookie_zookie wrote: Red89 wrote: fully sick coily wrote: i recon it will fit  Youre an idiot. Rookie_zookie wrote: i think u might not get me sorry the front end comes with 2 side guards the front part and grill and the bonnet Did you look at the link boosted brick posted ? If you put all those parts on that you just listed the bonnet wont sit level where it meets the part at the bottom of the windscreen.  ok calm down i was on my phone when i asked this my phone did not let me load the link if i dont ask questions i wont learn boostedbrick wrote: A coily bonnet on a WT will sit higher and look wierd. boostedbrick wrote: If you fit the entire coily front end, the bonnet will not fit. You obviously missed the part where he said it wouldnt fit properly too, twice
Rookie_zookie
 Posted: Sat May 19, 2012 5:32 pm |
i no that i no a little work would need to be done i want to see how much
fully sick coily
 Posted: Sat May 19, 2012 7:08 pm |
Bruce wrote: Red89 wrote: fully sick coily wrote: i recon it will fit  Youre an idiot. x2 i know people tell me that everyday at work
