It is currently Fri Jun 26, 2026 7:42 pm
Post Posted: Sun May 20, 2012 12:07 pm
i have a spotty i got ages ago to use as a reverse/work light for the rear of my jimny. i making the pole is the easy part, just want to know how other people have run their wires for their lights.
Post Posted: Sun May 20, 2012 1:12 pm
Basically, you will need the following...
SPDT Centre Off switch
Relay
Fuse
Suitable wire for light current
BATT (power)
Reverse wire
Earth
Can you draw a circuit that will work for you?
Post Posted: Sun May 20, 2012 1:19 pm
i know how to wire it i just wanna know how to get the wire out the back door to the light. should have been a bit clearer in my first post.
Post Posted: Sun May 20, 2012 3:15 pm
Run the cable through to the hinge side of the door and behind the interior panel, feed it through the rubber boot conduit to the door, drill a hole in the door's outer skin and stick a rubber grommet in the hole.
Don't drill into your spare ;)
Post Posted: Sun May 20, 2012 3:23 pm
ok cool, i was hoping to avoid drilling a hole but if i have to i have to. rubber grommet and lots of silicone :lol:
Post Posted: Sun May 20, 2012 4:30 pm
Get one of the grommets that are closed and put a single hole in it with a nail. Force the cable through the tiny hole and it shouldn't need silicone.
Users browsing this forum: Google [Bot] and 337 guests
