It is currently Sat Nov 07, 2026 8:32 pm
Post Posted: Sun May 20, 2012 6:14 pm
OK putting one of these on the vit
http://www.ebay.com.au/itm/ENGINE-WATCH ... 1e6e35f3af
Ideas on the most stable place to put the sensor? Ive got similar on the mini near a coolant blanking plate but cause it gets a bit of wind when you are moving the temp moves around a bit so I dunno how well it will work should things go bad
Thinking under an inlet manifold mounting stud? or maybe the water housing on the back of the head?
Vehicle: '94 suzuki maruti
Post Posted: Sun May 20, 2012 10:26 pm
i have the same in my sierra. the instructions say to put it on a bolt on the engine coolant outlet point, so i attached mine to thermostat cover, under one of the bolts there... works much quicker than standard gauge. temp on that beeps at me (i set mine to 95 degrees) while stock gauge is just passing halfway mark
Post Posted: Sun May 20, 2012 10:56 pm
would there not be a positive side to putting it actually on a head bolt? (while doing a head job) so that you getting the head temp, or is a bolt off the thermo housing enough?
ill be doing this on mine.
Post Posted: Sun May 20, 2012 11:09 pm
Post Posted: Sun May 20, 2012 11:18 pm
alien wrote:
you want to give one aye? stop spamming a good thread!
Post Posted: Mon May 21, 2012 6:35 am
Head bolts are well down under the cam and rocker cover, not to mention a soft washer under a head bolt is a no no
Thermostat housing is only going to measure the coolant temp change heating it, its not going to measure cylinder temp and all and would probably read cool if all the coolant was lost
Post Posted: Mon May 21, 2012 12:33 pm
Lower intake stud/ bolt toward the back of the head? Been a while since I've seen a G16 so can't think of any better spots.
Post Posted: Mon May 21, 2012 3:29 pm
Reckon the rear would run any hotter - cooler than the rest?
Post Posted: Mon May 21, 2012 3:53 pm
Thinking less chance of wind blowing thru and upsetting reading, also furtherest from water pump.
Where did your gasket blow? Did it overheat?
Post Posted: Mon May 21, 2012 4:01 pm
Come to think of it, most head gaskets I've done (that have blown from overheating) have gone around cylinder 3 or 4 (3 or 6 for V6's)
Post Posted: Mon May 21, 2012 4:27 pm
Gasket was fine, head cracked front to rear, didnt read hot on the gauge (gunked up sender) lot of oil in the water though :)
Vehicle: '96 LWB trayback
Post Posted: Mon May 21, 2012 11:06 pm
I run one of these on my zook. sits under a thermostat bolt at the rear of the head (gti).
I rely on it moreso than the dash temp these days. Sits at 82-86 degrees almost constantly so my overheat alarm is at 90.
Has been a lifesaver during a total loss of coolant (lower radiator hose split).
The only frustrating feature is the overheat alarm will usually sound for a while when you stop then restart the car due to heat soak.
Post Posted: Tue May 22, 2012 6:38 am
when you lost coolant, did it start to read higher quickly? did the normal temp gauge read cool?
Just curious what it all did
Post Posted: Tue May 22, 2012 8:42 am
Normal gauge showed no change, watch dog hit the alarm then up to 100 in under a minute so a good warning for me to pull over and check.
Having the display in clear view, you get used to what's normal and soon jump when something changes
Post Posted: Tue May 22, 2012 9:38 am
what one you have mark?
Post Posted: Tue May 22, 2012 9:59 am
Same as the one Royce linked too. Was the first thing I added to the zook after having overheating issues in my old one.
After ~5 years of using it, multiple drownings, filling it full of water etc it still works flawlessly and does exactly what I ask of it. Can't say anything bad about them.
Post Posted: Tue May 22, 2012 10:29 am
sweet, how big is the gauge?
Post Posted: Tue May 22, 2012 10:41 am
At a glance, Display is ~ 30mm H x 70mm W x 50mm D, plus mounting "wings" for screws on one side.
You could flush mount it in a dash somewhere if you were tricky. I've got mine mounted under the dash/glovebox. It's obvious enough to catch my eye when I want to check temp while driving, but not glaring in your line of sight.
Post Posted: Tue May 22, 2012 8:39 pm
Might invest in one myself now...
Post Posted: Fri May 25, 2012 6:02 am
http://www.ebay.com.au/itm/ENGINE-GUARD ... 2a1c4750dc
are these just as good?
MY BUILD THREAD HERE!!!!!
Post Posted: Fri May 25, 2012 6:35 am
Scales wrote:
http://www.ebay.com.au/itm/ENGINE-GUARDIAN-WATCHDOG-THERMO-FAN-CONTROL-RELAY-KIT-/180863062236?pt=AU_Car_Parts_Accessories&hash=item2a1c4750dc
this one looks the good and feature packed
watch the fan vid
Post Posted: Sun Jun 10, 2012 12:09 pm
how did you go Royce? did you get it and is it working effectively?
Mitch
Post Posted: Mon Jun 11, 2012 8:09 am
yeah seems to be pretty consistent, I guess I could dump the coolant to test it but somebody else can fix the mess
Interesting that it shoes a few degrees hotter at 2500rpm in nay gear, I think where I have it attached it might be reading temp from teh EGR, ill have to plug my thing in and see when the EGR is on
Post Posted: Mon Jun 11, 2012 10:56 am
thanks for that, where did you decide to mount? rear of the block or thermostat rear bolt?
Post Posted: Tue Jun 12, 2012 6:49 am
its on the rear upper inlet manifold bolt, closest I could get to the chamber side of the head, I think anything on the high side of the head might be slow to react as the head is quite hollow
Vehicle: sierra
Post Posted: Tue Jun 12, 2012 7:55 am
would it be worth finding out if its a NTC or PTC probe and getting wone that screws into the standard temp prob mount and getting one of the hose temp fittings (super dear auto things) as then the probe is in the liquid and has direct contact?
Vehicle: 2018 DMAX
Post Posted: Tue Jun 12, 2012 8:25 am
Wouldn't help if there was no coolant to contact for a temp reading.
Vehicle: sierra
Post Posted: Tue Jun 12, 2012 7:43 pm
tru, but it would give an odd reading still
Post Posted: Tue Jun 12, 2012 7:45 pm
The idea of it is a separate measurement of engine temp, measuring the metal itself rather than coolant, so if there is a problem with the cooling system this will alert you to it
There are already plenty of ways to measure coolant temp
Users browsing this forum: Google [Bot] and 111 guests
