It is currently Wed Aug 05, 2026 11:45 pm
Vehicle: 99 SJ80 Coily SR20DET
Post Posted: Mon May 21, 2012 7:12 pm
Hey Guys I've got issues that you all probably have too with the rear arms in my coily.
Its my competition truck so is not quite standard but for my class I need to retain my standard rear suspension, I've transferred the original mounts over from the diff onto a solid prado diff. they are exact to the T. problem is that with a bit of power on and a whole heap of grip the arms bend sideways or just snap in two.
Do any of you know of aftermarket arms? or where I can find out the specs of the cast material of these arms so I can try cast something stronger.
Post Posted: Mon May 21, 2012 7:15 pm
Cromo tube arms within your rules??
Post Posted: Mon May 21, 2012 7:21 pm
No sorry, I've currently got mild steel arms that we built to the same dimensions, shape, just slightly thicker (you couldn't tell) and not allowed in class
Post Posted: Mon May 21, 2012 7:26 pm
If you can swap whole axle assembles (and clearly do one or two wither modifications :D) then surely you can use a different arm so long as it is configured the same way? Lots of cars use radius arms and all of them would be stronger than coil sierra arms. I prefer Range Rover.
Post Posted: Mon May 21, 2012 10:58 pm
Rangie as Steve suggested or Patrol or 80 Series or Pajero or Bundera.
I think Paj are the shortest.
Post Posted: Tue May 22, 2012 6:58 am
Gen II paj arm's
Post Posted: Thu May 24, 2012 6:08 pm
No way around it unfortunitly, the arms, mounts , shock lengths, springs all have to be standard.
Doesn't help that these arms are like hens teeth over here
Post Posted: Thu May 24, 2012 6:42 pm
I have a pair of rear coily arms here. Yours for $70 plus freight.
Post Posted: Thu May 24, 2012 6:48 pm
A) Where are you? NZ? Coilers are pretty uncommon here too.
B) There's no cast aftermarket arms as far as I know. I guess you would have been trying to pass off aftermarket arms as factory?
Without knowing more about the class you are racing in I can't offer any real advice. When do they bend? Big side loads? under power?
Can Jimny arms fit? They are a fair bit more common - 14 years of production vs 2.
Can the arms be braced/laminated? Perhaps with the right welding procedure it could be achieved.
Post Posted: Fri May 25, 2012 9:26 am
What about a brace that bolts around the arms
That way the arm isnt moded in any way
Post Posted: Fri May 25, 2012 9:27 am
R u running rubber bushes
I found that the plastic ones would bend the arms before the bush started to twist
Post Posted: Sat May 26, 2012 4:21 am
A mate of mine has flogged trailing arm bushes in his gu patrol but says the little bit more give in them helps flex.
SJ80 Coily 2 inch body+40mm lift+31 inch M/T=:D
Vehicle: 1985 lwb sierra UTE
Post Posted: Thu May 31, 2012 11:14 am
What another off road armory they even do life time warranty if u can use them in class
Green? greeeen is nice !
Users browsing this forum: Google [Bot], J0hannes and 239 guests
