It is currently Mon Jun 22, 2026 11:07 am
Post Posted: Thu May 24, 2012 9:43 pm
I have to replace a broken mount due to too much right foot and 5.14 gears. Are the mounts sold on Ebay any good or am I better off trying to get genuine Suzuki parts?
Post Posted: Thu May 24, 2012 9:51 pm
link?
Post Posted: Thu May 24, 2012 10:29 pm
http://www.ebay.com.au/itm/230502161825 ... 1423.l2649
Post Posted: Thu May 24, 2012 10:46 pm
Those will be better than the broken ones, but your gears will still bust them.
Have a look in the business section at BYE products. Unbreakable mounts.
You may need to brace your steel mounting arms though.
Vehicle: '96 LWB trayback
Post Posted: Thu May 24, 2012 11:17 pm
I recommend caution with the "unbreakable" style of mounts these days. For me it's been a downward spiral of broken parts as I shift the weak point further down the drive train.
Started with broken transfer mounts, so went with unbreakable ones.
Started bending transfer arms, so made unbendable ones.
Ripped mounts off the chassis, so went to a solid mount system with through bolts on polyurethane mounts.
Started breaking gearbox and engine mounts so added unbreakable box mount and VL engine mounts.
Now I regularly sheer driveshaft bolts. 4 sets in 3 drives. I imagine once they're upgraded, uni joints will be next to die.
Sometimes a known "fuse" that is easy to replace like a transfer mount can be useful, provided breakage isn't a regular thing.
Post Posted: Fri May 25, 2012 3:11 am
mark would you care to say how much power is being transfered through your zook tho :lol:
Post Posted: Fri May 25, 2012 5:15 am
Without sounding nasty, gee you must be hard on your zook. My comp zook (Casper) was the first to have the unbreakable mounts fitted from Greg and they have been in for years now. I give my zook hell on the track and nothing has bent or broken. I have 5:14:1 t/case.
Post Posted: Fri May 25, 2012 5:48 am
Macca52 wrote:
http://www.ebay.com.au/itm/230502161825?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Got myself 3 of these and they are rubbish. Clag glue could do a better job bonding between the rubber and mounting plate.
LTM21 broke 2 within 200 metres and that was on a fire trail. Stock 1.3, 6.5s, 235 tyres, and he has a gentle foot. (Most of the time. :wink: )
I have gone through 3 myself but have bigger tyres and a 1.6. I now use a modified VL engine mount.
SS
Post Posted: Fri May 25, 2012 8:46 am
Dmac, he is talking about T/case mounts here not engine mounts. :-)
Post Posted: Fri May 25, 2012 3:29 pm
My unbreakable mounts are still flexible and allow the case to torque but limit the movement. Could you still bend stuff -yes. Our comp car, gets driven as hard as any other, to and often beyond its limits yet the mounts have held up.
We run:
33 tyres
6.5 gears
3.9 diffs
Unbreakable mounts
Custom transfers arms
Roctoy ring
The only damage to the mounts has been caused by hitting rock
Post Posted: Fri May 25, 2012 5:31 pm
I gather just-cruisin is BYE products. Can you give me a price for a set please. I will just have to learn to be a little bit kinder to the poor Zook
Post Posted: Fri May 25, 2012 5:40 pm
Yes Just_cruizin is Bye products.
Not trying to give Greg a big head but these are good. Can highly recommend them.
Give him a PM mate just so he does not miss your post.
And your pricing will be here
viewtopic.php?f=15&t=15518
Post Posted: Fri May 25, 2012 5:56 pm
Those ebay mounts you linked are no good, Buy genuine Suzuki ones way more flex-able.
My Maruti build, Click WWW
Vehicle: 1985 Holden Drover
Post Posted: Fri May 25, 2012 6:05 pm
Hey guys just a quick relevnat question, when i got my calmini transfer cradle from LROR i got 3 blue mounts with steel tubes inside. Anyone have any comments on these?
1989 WT Sierra.
Post Posted: Fri May 25, 2012 7:16 pm
So am I. :roll:
I use a VL engine mount on the single side of the Transfer case. :wink:
SS
Post Posted: Fri May 25, 2012 7:29 pm
what about kyzermattingley's seatbelt trick but over a stock mount? =)
kyzermattingley wrote:
Also found that one of my heavier duty transfer case mounts had torn, so I used an old trick I'd been taught which involved wrapping them in a seat belt, just melt a whole with a soldering iron where the studs will poke through, has to be really tightly done, works a treat on track car engine mounts. These mounts also spaced the transfer up about 15mm.
btw - maruti mounts suck - you're better to get ones out of a used zuk from a wrecker.
Post Posted: Fri May 25, 2012 7:50 pm
i'd say they're blue & fit the calmini transfer cradle :o
Post Posted: Fri May 25, 2012 7:56 pm
I meant if they are any good or not :P
1989 WT Sierra.
Post Posted: Fri May 25, 2012 8:07 pm
something wrong there.
mine runs solid alloy mounts bolted right though and Ive never bent or broken anything and that on 34's and 6.5's , ask any of the vic guys I drive with and they will tell you I dont baby my car.
Post Posted: Fri May 25, 2012 8:25 pm
Solid alloy mounts! How's the vibrations?
Post Posted: Fri May 25, 2012 8:30 pm
dont notice any adverse vibes, you can really hear the gears going round throught the vehicle however
Post Posted: Fri May 25, 2012 8:31 pm
I used 2" bodylift mounts which are close enough to solid mounts, have lasted for a few years now no dramas, swapped to rubber ones for the last trip and destroyed them in 1/2 an hour, back to solid mounts again now.
Made in JP. Built in WA.
Post Posted: Fri May 25, 2012 9:29 pm
Haha i love my whine!
1989 WT Sierra.
Vehicle: Sierra
Post Posted: Sat May 26, 2012 9:52 pm
I run polaris engine mounts for transfer case mounts. They stretch as much, maybe even more than stock mounts but apparently have a higher tearing point. Solid mounts seem to work for a lot of people but personally I much prefer having rubber mounts to absorb some shock loads.
Users browsing this forum: No registered users and 21 guests
