It is currently Sun Sep 27, 2026 5:00 am
Post Posted: Sat May 26, 2012 3:12 pm
Hey guys, any ideas? I thought it was just dirty contacts behind the cover thingo, but after giving it a good clean up i've still got nothing... figured i might as well just ask rather than spending ages trying to work out whats going on... last weekend is when it stopped working - i went to toot twice, worked once then had nothing since.
Thoughts??
Post Posted: Sat May 26, 2012 3:51 pm
Fuse? Connections in the steering wheel?
Post Posted: Sat May 26, 2012 5:48 pm
i have the same thing.....just yell out! haha
back in a built sierra!
Post Posted: Sat May 26, 2012 5:50 pm
i didnt think the horn had a fuse??? does it?
Spose i'll pull the steering wheel off tomorrow and see what i can see.
as for yelling out, doesnt work =) and with WA drivers being as shit as they are you frequently need to let them know you're there when they try to cut you off!
If you hold the horn depressed and turn the wheel does it work?
Post Posted: Sat May 26, 2012 5:54 pm
Just gave that a try... nope, nothing. Even turned IGN on just in case (and to release the steering lock).
Vehicle: SJ80, SE416
Post Posted: Sat May 26, 2012 7:10 pm
Have you tried taking the steering wheel off and earthing the copper rod that sticks out of the combo switch bit?
If the horn sounds when this happens then i'd say it's worn down too far. You could try soldering a bit on the end.
Also, check your steering column is earthed - there is a spring in the rag joint next to the steering box for this.
Post Posted: Sat May 26, 2012 7:17 pm
thanks mate i'll check that out tomorrow =)
Post Posted: Sat May 26, 2012 7:23 pm
My money is on the metal connecter in the rag joint
Post Posted: Sat May 26, 2012 7:38 pm
whats the solution if the rag joint is shot?
Post Posted: Sat May 26, 2012 7:42 pm
I ran a wire around, temporarily,
stayed that way for years.
Its just that the rubber can't conduct current.
Post Posted: Sat May 26, 2012 7:44 pm
http://www2.izook.com/?page_id=325
Post Posted: Sat May 26, 2012 8:22 pm
Cool, thanks mate =)
Vehicle: Jeep
Post Posted: Sun May 27, 2012 12:28 am
Those stock electric horns dont like mud and water in them, the actual horn may be dead... time to get rid of the electric horn, and get some air horns fitted... :wink: :D
Post Posted: Sun May 27, 2012 9:03 am
I moved my Vitara horn to up high on firewall, because it stopped working full of mud.
A good fush and some wd40 got it working.
So Yes, that is worth a look at.
I may have ahorn left over from my Sierra, if thats the issue.
Post Posted: Sun May 27, 2012 1:38 pm
alrighty... steering wheel all cleaned up and contacts all good... no dice.
so i unplugged the horn's crimp plugs and ran a wire from one to the battery, and a wire from the other to various metal on the body and chassis (and vice versa in case polarity matters) and the horn still didnt go off... so im guessing the horn itself has shat it - im guessing what i've done is a good enough test to confirm that???
I've even taken the horn out and tried to wire it to the battery that way and its still not working.
Rag joint on the steering looks fine, although dirty... everything has been hit with inox.
Post Posted: Sun May 27, 2012 2:05 pm
inox up the throat of the horn may work.
After WD40 I had to retune mine before it worked well.
Theres a screw lock nut thingy on them.
Or new ones ain't much.
Post Posted: Sun May 27, 2012 2:55 pm
My horn always worked when i didnt want it to, Then didnt work when i wanted it to. I pulled the fuse. Fixed.
Post Posted: Sun May 27, 2012 2:58 pm
bought a narva high tone one:
90mm dia. frequency 450 Hz
Decibel rating 112dB
fuck its loud! hahahaha
works perfectly.
Vehicle: Coil Sierra
Post Posted: Sun May 27, 2012 8:50 pm
Twin air horns off barina, astra and vectra are good. Cost $10 from wreckers.
Vehicle: Clown Car..
Post Posted: Sun May 27, 2012 9:07 pm
http://www.ebay.com.au/itm/Stebel-Nauti ... 3a74a0f32a
personally run one of these..Straight off the standard horn plugs... Its pretty damn loud and alot less F-ing around and compact than the 3 tube airhorns and such..
Post Posted: Sun May 27, 2012 11:03 pm
hahah i looked at those nautilus ones a while back... they look INSANE - but way too expensive for me. That said, that's the cheapest i've seen one... most were closer to $100.
Users browsing this forum: Google [Bot] and 947 guests
